ilogic Rule for "update properties"
MarkusGreifeneder3360
im looking for an ilogic Rule,
thats starts the exisiting Inventor command "update properties" (in the Vault-Tab) with an ilogic Rule.
Ideally with automatic "OK" when window appears.
Can someone help
Thanks in advance,
Markus
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @MarkusGreifeneder3360,
Please try the below iLogic rule to update properties and activate "Ok" button automatically.
Dim updateCmd As ControlDefinition
updateCmd = ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack")
updateCmd.Execute
Dim oKCmd As ControlDefinition
oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd")
oKCmd.Execute
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
