ilogic Rule for "update properties"
MarkusGreifeneder3360
im looking for an ilogic Rule,
thats starts the exisiting Inventor command "update properties" (in the Vault-Tab) with an ilogic Rule.
Ideally with automatic "OK" when window appears; but not necessarily ...
Can someone help
Thanks in advance,
Markus
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @MarkusGreifeneder3360,
Please try the below iLogic rule to update properties and activate "Ok" button automatically.
Dim updateCmd As ControlDefinition
updateCmd = ThisApplication.CommandManager.ControlDefinitions.Item("VaultPropertyWriteBack")
updateCmd.Execute
Dim oKCmd As ControlDefinition
oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd")
oKCmd.Execute
Please feel free to contact if there is any doubt.
If solve problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
How do you activate the "OK" button automatically.  For some of reason I can't seem to figure it out.
I am having this same issue.  How do you have this complete the update automatically?  It pauses when it is time to close the dialog box.
If it would hit enter it would work.
It doesn't work automatically .... we click "OK"
updateCmd.Execute
oKCmd.Execute
is there a way to make your code run your code on save an idw. and then only update the first level iam/ipt in the drawing  ? without any user interaction other then hit the save Buttom?
