iLogic rule for deleting or replacing files in a folder
Hello
Is there a iLogic rule to Opne, Save (as stp and PDF) , delete olde versions, and close the file. I whant to start the rule from a assembly file, and i have 3 parts to be saved as stp and PDF. I have this rule, but with this i open, save, and close the part. The old parts are in the folder. (this rule save the parts as "Position X" , where X is a parameter from excel)
When i save ther rule as "Positon 3" Position 2 shuld be deleted.
So, i need to have 3 PDF and 3 STEPS from the current position
Here is a rule that save as STP (Position = parameter from excel)
'get the part
part = Component.InventorComponent("Glashalter mittig:1")
'open the part
doc = ThisApplication.Documents.Open(part.Definition.Document.FullDocumentName)
'oPath = ThisDoc.Path & "\"
' save the part as step
' doc.SaveAs(oPath & "Glashalter mitte position_" & Position & ".stp" , True)
stp1=doc.SaveAs("C:\Users\Aleksandar.Jovicic\Desktop\FGL\Fertigung\Glashalter\Glashalter mitte " & Position $".stp" , True)
' close the part
doc.Close()
Have you tried this?
SyntaxEditor Code Snippet
        Try
            My.Computer.FileSystem.DeleteFile(*FULL PATH OF FILE YOU WISH TO DELETE*)
            Catch
            MessageBox.Show(DeleteFile & vbLf & " . . . can not delete file, or file not found.", "iLogic")
        End Try
Hi and thank you for the reply!
can you PLEASE writhe down the colde in combine with my to know how the cold shuld look like. My folder path is is:
"C:\Users\Aleksandar.Jovicic\Desktop\FGL\Fertigung\Glashalter" (delete old versions of PDF and STP)
I guess it'd be something like this
        Try
            My.Computer.FileSystem.DeleteFile("C:\Users\Aleksandar.Jovicic\Desktop\FGL\Fertigung\Glashalter\Glashalter mitte " & (Position-1) &".stp")
            Catch
        End Try
Hope it helps
MechMachineMan
Dim oFiles As String()
Dim oFile As File
oFiles = System.IO.File.GetFiles(oYourFolder, "*.ipt") 'Or other file type
For Each oFile in oFiles
      'String operations to shrink down the file name to whatever is after the last parenthesies
             If 'condition for delete here
                            System.IO.File.Delete(oFullFileName of file to delete)
             End if
Next
https://msdn.microsoft.com/en-us/library/system.io.file%28v=vs.110%29.aspx
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hello MechMachineMan and thank you for the replay
When i use the rule i bekomme a erro in this part:
oFiles = System.IO.File.GetFiles(oYourFolder, "*.pdf") 'Or other file type
should this park look like this:
oFiles = System.IO.File.GetFiles("C:\Users\user\Desktop\ Glashalter mitte", "*.pdf") 'Or other file type
or?
MechMachineMan
I believe so, yeah. The oYourFolder is just in there as the variable string
to represent whatever you want it to be. I also added the link so you can
check out the syntax for yourself.
Justin K
