iLogic rule for bending certain thickness
Can someone help me with an iLogic rule for creating a certain thickness for bending
it should look like this
up to a sheet thickness of 4mm , bend = strength
from 4mm up to 8mm bend=thickness *1,5
from 8mm up to 12mm bend =thickness*2
from 12mm up to 22mm bend=thickness*3
Thank a lot
bradeneuropeArthur
Could you please explain a bit further because I don't understand exact what you need?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Well,
In inventor, you can only enter the bending radius value and you have to change it manually for each radius value.
I want to create a rule to set the bend radius based on the thickness. ( I know it can be performed by setting up the Sheet metal Style but I want a rule for it 🙂
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject And _
ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value = "Sheet Metal" Then
Dim oCD As SheetMetalComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
If oCD.Thickness.Value <= 4 Then
oCD.BendRadius.Expression = "Thickness"
If oCD.Thickness.Value <= 8 Then
oCD.BendRadius.Expression = "Thickness * 1.5"
If oCD.Thickness.Value <= 12 Then
oCD.BendRadius.Expression = "Thickness * 2"
End if
bradeneuropeArthur
If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject And ThisApplication.ActiveDocument.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value = "Sheet Metal" Then
	oCD.SheetMetalStyles.Item(1).BendRadius ="Thickness"
	End If'
oCD.SheetMetalStyles.Item(1).BendRadius ="Thickness * 1.5"
oCD.SheetMetalStyles.Item(1).BendRadius ="Thickness * 2"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Modified.
because the value is in Cm and needs to be multiplied by 10
	If oCD.Thickness.Value * 10 <= 4 Then
	End If'
If oCD.Thickness.Value * 10 <= 8 Then
If oCD.Thickness.Value * 10 <= 12 Then
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
i have the following error when i run the rule
Maybe I have to modify something also in editor sheet metal style?
