Ilogic rule created by someone who left the company not working. Help needed
arnaud.henry-lefort
Message 1 of 11
arnaud.henry-lefort
Sadly the person who did our ilogic left and since the last update the rules are not working anymore.
I am wondering if someone can help to make them work again ?
'Activate current document
oDocType = ThisApplication.ActiveDocument
'hide error
ThisApplication.SilentOperation = True
'Exit if current document is a drawing
If oDocType = kDrawingDocumentObject Then
	Return
'Exit if current document is a not and assembly
If oDocType <> kAssemblyDocumentObject Then
	Return
Dim oDoc As Document = ThisDoc.Document
Dim oDef As AssemblyDocument = oDoc
Dim AppearanceLibraryName As String = "Rootwave Finish Library"
' Get the appearance library
Dim AppLib As AssetLibrary = Nothing
Try
	AppLib = ThisApplication.AssetLibraries.Item(AppearanceLibraryName)
Catch
	MsgBox("Couldn't find a appearance library called '" & AppearanceLibraryName,, "Error")
	Exit Sub
End Try
Dim AppColours As AssetsEnumerator = AppLib.AppearanceAssets
Dim ColourArray As New ArrayList
' Write all the appearance names to an arraylist
For Each A As Asset In AppColours
    ColourArray.Add(A.DisplayName)
Next
 Sort the array alphabetically
ColourArray.Sort()
' Create 3 parameters with the list of appearances in......
 Parameter 1
Try
MultiValue.List("RootwaveFinish") = ColourArray
Catch
 Parameter doesn't exist - create it
Dim oParam As Parameter = oDef.Parameters.UserParameters.AddByValue("RootwaveFinish", ColourArray(0), UnitsTypeEnum.kTextUnits)
End Try
Replies (10)
Message 2 of 11
marcin_otręba
check now:
oDocType = ThisApplication.ActiveDocumentType
'hide error
	Return
Dim oDef As AssemblyComponentDefinition = oDoc.componentdefinition
Try
Catch
	Exit Sub
End Try
Next
 'Sort the array alphabetically
ColourArray.Sort()
 'Parameter 1
Try
Catch
 'Parameter doesn't exist - create it
End Try
ThisApplication.SilentOperation = False
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 11
bradeneuropeArthur
Maybe I can provide you and all others a tip.
Declare everything correctly even if i-logic lets you work without doing it correct.
If this was done in the beginning the programmer found out their mistake in the early phase and you were not left in the dark.
Please let us know if you need any support.
I can imagine that this will more often going to happen in future maybe.
Let us guide you through this phase then.
Good job @marcin_otręba
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 11
arnaud.henry-lefort
Thanks for this.
Can you let me know what you changed ? I can't see the difference 🙄
Message 5 of 11
arnaud.henry-lefort
Well I have probably 5 / 6 script that do not work anymore and I try to find what they use to do 😞 if you want to jump in you are welcome !
Message 6 of 11
marcin_otręba
sure,
i corrected variable doctype to be assigned as it suposed:
was:
correct:
 also oDef should be definition instead of document:
was:
correct:
i also corrected missing comment quotes:
ColourArray.Sort()
 Parameter 1
 to:
ColourArray.Sort()
 'Parameter 1
Message 7 of 11
bradeneuropeArthur
Yes please give me access to your code and I will have a look.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 11
bradeneuropeArthur
Dim InvApp As Inventor.Application = ThisApplication
Dim oDocType As Inventor.DocumentTypeEnum = oDoc.DocumentType
If Not oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
	Exit Sub
Try
	AppLib = InvApp.AssetLibraries.Item(AppearanceLibraryName)
Catch
	Exit Sub
End Try
'hide error
InvApp.SilentOperation = True
Next
ColourArray.Sort()
 'Parameter 1
Try
Catch
End Try
InvApp.SilentOperation = False
Some editorial changes for better reusability an readability in future.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 11
arnaud.henry-lefort
thanks for this guys. So far with what you changed I managed to update some scripts in one that does all. I am learning ! I will share my code once done as I am sure i can be improved !
I have a form in the ilogic who is trigger by a button. Any idea where I can find the code or modify the form ?
Message 10 of 11
marcin_otręba
Right click on that form button, you should have edit command  under RMB menu. If not then check your external ilogic UI folder if you have rights to save there, or if it is read only.
Message 11 of 11
arnaud.henry-lefort
Thanks ! this helped a lot in my trouble. I been able to locate another folder where the ilogic rule have been saved and works !
