iLogic - Rule Automation / Breaking Points in Code
jhunt3Z5BG
jhunt3Z5BG
I Used your solution (@JelteDeJong ) and inserted the concept in some code I was working on; some borrowed from @Anonymous. I attached the code in a text file and my excel data sheet.
The problems I am seeing are as follows:
  • When I have a qty of more than 1 it errors out
    • I Want to add more than 1 VC if there are more than 1 qty in the spreadsheet
  • When any of the cells are blank, it errors out
    • I want it to continue if they are blank, if possible
  • Is there a nifty way for the iLogic Program to automatically figure out how many cells to check in excel without me stating to check 2,000 rows, as these rows may change per spreadsheet?
I was wondering if you (@JelteDeJong ) or Curtis ( @Anonymous) might be able to assist. I think it is simple, I am just missing it.
JMGunnar
Here my solution
if there write END in A column or A column is empty it exit
Best regards Johan G
For i = 2 To 2000
						If i = 2 Then
							occName = GoExcel.CellValue(ExcelPath, "Blad1", "A" & i)
							oFileName =  GoExcel.CellValue("B" & i)
						Else If GoExcel.CellValue("A" & i) = "END" Or String.IsNullOrEmpty(GoExcel.CellValue("A" & i))  Then
							Exit For
						Else
							Try
							Catch
								Exit For
							End Try
						End If
		Next
jhunt3Z5BG
@JMGunnar  My apologies for the late response, I was in a training session all day. First of all thank you for your response. I went a different route. I did a simple if statement to solve one of my issues
	If oProp1 = Nothing Then
		oProp1 = " "
	End If
 I was able to also create a method to automate the data extents, along with creating some code for the user to select their spread sheet to use.
Outstanding Issue:
My only issue is when I have a qty 2 of any virtual component it errors out. It used to work, until I added code to add my custom iProperties to the VC's.
The code is in the main section of the attached code file (word Document). I grabbed this code from one of @Anonymous posts. It worked well until I added my custom iProperties.
	'Dim index As Integer
	index = 2
	Do While index <= iQTY
		occs.AddByComponentDefinition(virtOcc.Definition, oMatrix)
		index += 1
	Loop
JMGunnar
I Change
      index += 1
 Loop
too  - >
    odef = oCVirtualCompDef
   occs.AddByComponentDefinition(odef, oMatrix)
index += 1
Loop
Johan
Dim oCVirtualCompDef As VirtualComponentDefinition
	Dim oNewOcc As ComponentOccurrence
	If iQTY >= 1 Then
		Dim PropertyName1 As String = "PN"
		Dim PropertyName2 As String = "NA"
		Dim PropertyName3 As String = "NB"
		 oNewOcc  = oAssDef.Occurrences.AddVirtual(sVirtPart, oMatrix)
		 oCVirtualCompDef  = oNewOcc.Definition
 '-----------------------------------------Population of Description iProperty
		Dim IDX As String = sVirtPart & ":"&index
			iProperties.Value(IDX, "Project", "Description") = oProp1
			'iProperties.Value(sVirtPart & ":1", "Project", "Description") = oProp1
'-----------------------------------------PN iProperty Creation & Population
		Dim customSet = oCVirtualCompDef.PropertySets.Item("Inventor User Defined Properties")
		Try
		    Dim prop As [Property] = customSet.Item(PropertyName1)
		    prop.Value = oProp2
		Catch ex As Exception
		    customSet.Add(oProp2, PropertyName1)
		End Try
'-----------------------------------------FAMILY iProperty Creation & Population
		Try
		    Dim prop As [Property] = customSet.Item(PropertyName2)
		    prop.Value = oProp3
		    customSet.Add(oProp3, PropertyName2)
		End Try
'-----------------------------------------NUMB iProperty Creation & Population
		Try
		    Dim prop As [Property] = customSet.Item(PropertyName3)
		    prop.Value = oProp4
		    customSet.Add(oProp4, PropertyName3)
		End Try
	End If
'-----------------------------------------Add the next instance starting at instance2 (if applicable)
	index = 2
		index += 1
	Loop
Next
jhunt3Z5BG
Any thoughts on the error message below when I entered in the code as prescribed?
JMGunnar
I have move  definition out
If iQTY >= 1 Then
End If
jhunt3Z5BG
I see what you did now. I made the changes as you mentioned and I noticed a couple other items I missed. I see why you pushed it out now.
Thank you!
