Display filename in pop up message
joseph.cooley
joseph.cooley
I'm trying to make a reminder that will have people select a non generic material.  When the file is saved it triggers this rule.
materialName = ThisDoc.Document.ComponentDefinition.Material.Name
If materialName = "Generic" Then
	MessageBox.Show("Please update material", "Generic Material")
iLogicVb.UpdateWhenDone = True
 The problem is that it doesnt tell you which file it is if there is a large assembly and a file inside is non specified.  How would I have the file say what the filename is within the popup message?
Michael.Navara
Try this update
Dim msg = String.Format("Please update material in {0}", ThisDoc.Document.DisplayName)
MessageBox.Show(msg, "Generic Material")
joseph.cooley
Yep that worked great! I added the file extension for additional clarity, Thank you!
Dim msg = String.Format("Please update material in {0}.ipt", ThisDoc.Document.DisplayName)
