iLogic return Edit in place
Log0ut
Log0ut
Hi
How I can use iLogic to return(exit) from part editing in assembly
theo.bot
When you are editing an ComponentOccurrence you can use ExitEdit to go back to the parent.
Log0ut
Can you write exact code?
JelteDeJong
This is an example iLogic rule:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim occurence As ComponentOccurrence = doc.ComponentDefinition.Occurrences.Item(1)
occurence.Edit()
MsgBox("The first occurence in your assmbly is now being edited." &
       " Click on 'ok' to return(exit) from part editing")
occurence.ExitEdit(ExitTypeEnum.kExitToTop)
Jelte de Jong
Blog: hjalte.nl - github.com
Log0ut
Is it possible do it on part level?
JelteDeJong
If you mean if its possible to do this from an PartDocument object, Then I don't think it's possible.
Jelte de Jong
Log0ut
Find solution:
Dim aDoc As AssemblyDocument = ThisApplication.ActiveDocument
oOcc = aDoc.ComponentDefinition.ActiveOccurrence
oOcc.ExitEdit(ExitTypeEnum.kExitToTop)
Thanks for directions!
