This is an example iLogic rule:
Dim doc As AssemblyDocument = ThisDoc.Document Dim occurence As ComponentOccurrence = doc.ComponentDefinition.Occurrences.Item(1) occurence.Edit() MsgBox("The first occurence in your assmbly is now being edited." & " Click on 'ok' to return(exit) from part editing") occurence.ExitEdit(ExitTypeEnum.kExitToTop)
Jelte de Jong
Blog: hjalte.nl - github.com
If you mean if its possible to do this from an PartDocument object, Then I don't think it's possible.
Jelte de Jong
Find solution:
Dim aDoc As AssemblyDocument = ThisApplication.ActiveDocument oOcc = aDoc.ComponentDefinition.ActiveOccurrence oOcc.ExitEdit(ExitTypeEnum.kExitToTop)
Thanks for directions!
