Create Sketch
Create Sketch
Cosmin_V
Create Sketch
Cosmin_V
I have this rule, which it works almost fine, maybe somebody can help me to make it work good.
-We use the inventor auto naming/numbering
-If I use whatever iProperties which is contain the part name whic is "00303076" in the sketch it is not appear the leading zeros. only "303076" . Can this be fixed?
And can the sketch somehow be position on the mouse pointer position?
This is my rule....
  Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select face")
    Dim face As Face = pick
    Dim faceBox = face.Evaluator.RangeBox
    Dim x As Double = faceBox.MaxPoint.X - faceBox.MinPoint.X
    x =  ThisDoc.FileName(False)
    Dim partDef As PartComponentDefinition = face.Parent.Parent
    Dim planarSketch = partDef.Sketches.Add(face)
    'Projected center of mass
   Dim position As Point2d = planarSketch.ModelToSketchSpace(partDef.MassProperties.CenterOfMass)
    planarSketch.TextBoxes.AddFitted(position, String.Format("{0}", x))
planarSketch.Name = "My_Sketch"
Many Thanks!
Michael.Navara
This two lines are not correct. You define x as double, but you try to set string to it.
Comment the first line and modify the second one.
'Dim x As Double = faceBox.MaxPoint.X - faceBox.MinPoint.X
Dim x =  ThisDoc.FileName(False)
line
Cosmin_V
thanks @Michael.Navara
That works!
Now the sketch position...to the mouse pointer...it is that possible?
Michael.Navara
Is it possible, but it is not easy. You can't use the simple Pick function, but you need to implement whole  SelectEvents.OnSelect Event functionality.
