iLogic : Restore drawing curves as standard layer
fsanchou
fsanchou
Manually, I select by Right clic on Component in Browser > Select As Edges. Then in Annotate Ruban > Format > Layer, I select By standard.
Is it possible to restore all drawing curves as standard layer with iLogic?
fsanchou
Anybody ? Maybe somebody from Autodesk?
fsanchou
I hope that Autodesk Answer Day will help me.
Do you have a solution?
Thanks.
wayne.brill
Here is an iLogic rule I worked up. This example changes the layer of the curves in a view. (the example prompts you to select the view)
' Select the DrawingView that has the drawing curves
	' that you want to change to a different layer
    Dim oDrawingView As DrawingView
    oDrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
    Dim oDrwCurveCollection As ObjectCollection
    oDrwCurveCollection = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oDrwCurve As DrawingCurve
	' Get the drawing curves and the segments of the drawing curves
	' and add them to the ObjectCollection
    For Each oDrwCurve In oDrawingView.DrawingCurves
        Dim oDrwCurveSeg As DrawingCurveSegment
        For Each oDrwCurveSeg In oDrwCurve.Segments
         oDrwCurveCollection.Add(oDrwCurveSeg)
        Next oDrwCurveSeg
    Next
    Dim oSheet As Sheet
    oSheet = oDrawingView.Parent
	' Get a layer to move the drawing curve segments to
    Dim oLayer As Layer
    'Try one of these layers
	'oLayer = ThisDoc.Document.StylesManager.Layers.Item("Bend Centerline (ANSI)")
    oLayer = ThisDoc.Document.StylesManager.Layers.Item("Visible (ANSI)")
    Call oSheet.ChangeLayer(oDrwCurveCollection, oLayer)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
fsanchou
Hi Wayne,
I use approximately this method but I need to check each type of segment, and to known the layer name.
Sometimes I have some errors: segment's layer change but not color.
Does there is no API feature that reproduce the manual method ?
wayne.brill
In some cases if there is a command that is being run you could execute that command from the API after geting things selected.
I do not believe using a command for this is possible. I used the UserInputEvents OnActivateCommand event and I do not see a command being fired when the curves are selected and the ribbon dropdown is used to change the layer.
Wayne
Wayne Brill
