Referencing specific dimensions in titleblocks
I've been working working with Curtis on a project involving editing dimensions of titleblocks using iLogic/VBA:
https://forums.autodesk.com/t5/inventor-general-discussion/passing-ilogic-parameter-into-dimension-v...
Currently the code is like this:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oTitleBlockDef As TitleBlockDefinition
oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("A-B")
Dim oSketch As DrawingSketch
oTitleBlockDef.Edit(oSketch)
Dim oDim As DimensionConstraint
For Each oDim In oSketch.DimensionConstraints
            If oDim.Parameter.Name = "d0" Then
            Exit For
Next
Select Case HeightCheck
    Case ActiveSheet.Height = 11
        oDim.Parameter.Value = (8.5 - 0.25  - 0.25  - 0.75 - (0.25*5)) * 2.54
        ThisApplication.ActiveDocument.Update
    Case ActiveSheet.Height = 17
        oDim.Parameter.Value = (11 - 0.25 - 0.25 - 0.75 - (0.25 * 5)) * 2.54
End Select
oTitleBlockDef.ExitEdit(True)
Where there's a for loop to search for a dimension labeled "d0", and then modifies it.
The problem is that I have to execute the rule *twice* for it to actually adjust to the sheet, which tells me that there's some kind of indexing problem or return value of the for loop, or something to that effect.
Is there a way to reference the 'd0' dimension explicitly by name and modify it without having to search for it?
rossano_praderi
no is not possible.
This is your code with some modifications.
i=0
Do
	i=i+1
	If oDrawDoc.TitleBlockDefinitions.Item(i).Name = "A-B"
		oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item(i)
Loop Until oDrawDoc.TitleBlockDefinitions.Item(i).Name = "A-B" Or i = oDrawDoc.TitleBlockDefinitions.count
i=0
Do
	i=i+1
	oDim = oSketch.DimensionConstraints.item(i)
		Select Case ActiveSheet.Height
			Case 11
			Case 17
		End Select
Loop Until oDim.Parameter.Name = "d0" Or i=oSketch.DimensionConstraints.count
May be this isn't the best solution, but work well.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
wayne.brill
Hi Robert,
Not sure if it makes sense for what you are doing but you could add an attribute to the DimensionConstraint. (This DevBlog post discussess attributes)
http://adndevblog.typepad.com/manufacturing/2013/03/save-extra-data-in-inventor-file-2.html
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
