Ilogic replace title block
Hi I've a msg box asking the user what kind of drawing is he making.
If the answer is yes (6) then Inventor will change the styles and delete the current title block and »»» replaces by an other with the name Ferramentas and it does delete the current one but does not place the other named Ferramentas, any ideia why?
TIA
Dim i As String
i = MessageBox.Show("Vai efectuar o desenho de uma ferramenta?", "ALUALPHA", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If i = "6" Then
		' mudar os estilos para ferramentas
	Dim oDoc As DrawingDocument
    oDoc = ThisApplication.ActiveDocument
	oDoc.StylesManager.ActiveStandardStyle = oDoc.StylesManager.StandardStyles("Alualpha Ferramentas")
	' defenir os title blocks
	Dim oTitleBlockDef1 As TitleBlockDefinition
	oTitleBlockDef1 = oDoc.TitleBlockDefinitions. _
    Item("Alualpha")
	Dim Val1 As Boolean = oTitleBlockDef1.IsReferenced
	Dim oTitleBlockDef2 As TitleBlockDefinition
	oTitleBlockDef2 = oDoc.TitleBlockDefinitions. _
    Item("Ferramentas")
	Dim Val2 As Boolean = oTitleBlockDef2.IsReferenced
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oTitleBlock As TitleBlock
		If oSheet.TitleBlock.Definition Is oTitleBlockDef1 Then
    	oSheet.TitleBlock.Delete()
	oTitleBlock = (oTitleBlockDef2)
	Else
	'mudar estilos para Alpha
	Dim oDoc1 As DrawingDocument
    oDoc1 = ThisApplication.ActiveDocument
	oDoc1.StylesManager.ActiveStandardStyle = oDoc1.StylesManager.StandardStyles("Alualpha")
wayne.brill
Can you try using AddTitleBlock() of the Sheet? I did this quick test using part of your code and it is adding the title block.
     'oTitleBlock = (oTitleBlockDef2)'wB commented
     oSheet.AddTitleBlock(oTitleBlockDef2) 'wB added
Sometimes it is helpful to test things in VBA. There is VBA sub in the help file that adds a title block. (InsertTitleBlockOnSheet). The Inventor API help is here on my system:
"C:\Program Files\Autodesk\Inventor 2014\Local Help\admapi_18_0.chm"
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Sorry for my delay but or I dont know where exactly were to put it or it gives the message above.
Dim i As String
If i = "6" Then
    Item("Alualpha")
    Item("Ferramentas")
	Else
What I did wrong
TIA
FG
wayne.brill
Please attach your idw file with the rule. It will allow me to quickly recreate the error.
Wayne
Wayne Brill
wayne.brill
Thanks for emailing me the idw file. I was able to recreate the error. Those title blocks have prompt strings in them. You would need to provide these. When I tested this for my first reply I just had geometry in the TitleBlock. Here is an update:
Wayne
Dim i As String
If i = "6" Then
    Item("Alualpha")
    Item("Ferramentas")
'    oTitleBlockDef2 = oDoc.TitleBlockDefinitions. _
'    Item("wBTest")
    'wB commented
'    Dim oTitleBlock As TitleBlock
'    If oSheet.TitleBlock.Definition Is oTitleBlockDef1 Then
'        oSheet.TitleBlock.Delete()
'        oTitleBlock = (oTitleBlockDef2)
'    End If
    Dim sPromptStrings(0 To 9) As String
    sPromptStrings(0) = "String 1"
    sPromptStrings(1) = "String 2"
    sPromptStrings(2) = "String 2"
    sPromptStrings(3) = "String 2"
    sPromptStrings(4) = "String 2"
    sPromptStrings(5) = "String 2"
    sPromptStrings(6) = "String 2"
    sPromptStrings(7) = "String 2"
    sPromptStrings(8) = "String 2"
    sPromptStrings(9) = "String 2"
    MessageBox.Show("right before AddTitleBlock" + oTitleBlockDef2.Name )
    oSheet.AddTitleBlock(oTitleBlockDef2, , sPromptStrings) 'wB added
 MessageBox.Show("right after AddTitleBlock")
    Else
'InventorVb.DocumentUpdate()
Wayne Brill
