ilogic browser is closed after Inventor crash
So, there are some users here that, when Invnetor crashes, they lose their ilogic browser (not a big deal) and ilogic configurator paths go back to default (is a big deal). Anyone ever experienced this or heard of it. If so any solutions?
Inventor 2013 SP2 Update 2
Thanks in advance!
adam.nagy
Autodesk Support
Autodesk Support
I have not heard of this issue, but one thing you could try is back up the iLogic configuration file and restore it after a crash:
http://forums.autodesk.com/t5/Inventor-Customization/iLogic-Configuration-Where-Stored/td-p/2974774
Cheers,
Adam Nagy
Autodesk Platform Services
This user config you are talking about. What all does it contain? We have a lot of users, all of which could and probably do have differnt settings.
adam.nagy
Autodesk Support
Autodesk Support
You can simply open it up in e.g. notepad and see it for yourself 🙂
It should contain all the settings you see in the iLogic Configuration dialog in the UI.
Adam Nagy
MegaJerk
I've had the browser get trashed after a crash, but never the actual iLogic paths.
So, nothing to add to the solution, but just more of a confirmation that not only you have experienced half of your problem 😉
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
