iLogic Rename Solid Bodies - all to select
kresh.bell
Message 1 of 15
kresh.bell
I use this iLogic to rename solid bodies. It works great. I do not know how to edit iLogic, so please help. Can this iLogic be edited so that just renaming select solid bodies, not all solid bodies?
'check for custom iProperty and add it if not found
Dim prefix As String = "Prefix"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
         prop= customPropertySet.Item(prefix)
Catch
      ' Assume error means not found
            customPropertySet.Add("", prefix)
End Try
'write the part number to the Prefix iProperty if it is empty
If iProperties.Value("Custom", "Prefix") = "" Then
iProperties.Value("Custom", "Prefix") = iProperties.Value("Project", "Part Number") & "_"
Else
'check that this active document is a part file
Dim partDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MessageBox.Show ("Please open a part document", "iLogic")
'define the active document
partDoc = ThisApplication.ActiveDocument
Dim solid As SurfaceBody
Dim i As Integer
'get input from user
prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix"))
'write input back to custom iProperty
iProperties.Value("Custom", "Prefix") = prefix
i = 1
'rename all solid bodies incrementing suffix
For Each solid In partDoc.ComponentDefinition.SurfaceBodies
solid.Name = prefix + Iif(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
Kresh
Replies (14)
Message 2 of 15
bradeneuropeArthur
Try this:
Public Sub main()
Dim a As Application
 a = ThisApplication
Dim b As PartDocument b = a.ActiveDocument Dim c As SurfaceBody Dim d As SurfaceBodies Dim e As SelectSet e = b.SelectSet If e.Count = 0 Then MsgBox "select something" Else Dim i As Integer 'get input from user Dim prefix As String prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix")) 'write input back to custom iProperty 'iProperties.Value("Custom", "Prefix") = prefix i = 1 'rename all solid bodies incrementing suffix For Each c In e c.Name = prefix + IIf(i < 10, "0" + CStr(i), CStr(i)) i = i + 1 Next 'e.Name = "" End If End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
kresh.bell
Message 4 of 15
bradeneuropeArthur
I-logic is different the vba and vb.net...
MsgBox ("select something")
 I have developed it in vba….
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 15
kresh.bell
Sorry but I do not understand, what do I have to do to make no mistake?
Message 6 of 15
bradeneuropeArthur
re-copy and paste...
Public Sub Main()
a = ThisApplication Dim b As PartDocument b = a.ActiveDocument Dim c As SurfaceBody Dim d As SurfaceBodies Dim E As SelectSet E = b.SelectSet If e.Count = 0 Then MsgBox ("select something") Else Dim i As Integer 'get input from user Dim prefix As String prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix")) 'write input back to custom iProperty 'iProperties.Value("Custom", "Prefix") = prefix i = 1 'rename all solid bodies incrementing suffix For Each c In e c.Name = prefix + IIf(i < 10, "0" + CStr(i), CStr(i)) i = i + 1 Next End If End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 15
kresh.bell
Message 8 of 15
bradeneuropeArthur
the custom property is missing.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 15
bradeneuropeArthur
Are you a little familiar with I-logic?
Since the question is not only what you asked.
You need to have a review for your complete copied code, isn't it?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 15
bradeneuropeArthur
Public Sub Main()
 a = ThisApplication
 Try
 Dim p As Inventor.Property = b.PropertySets.Item(4).Add("", "Prefix")
 Catch
 End Try
Dim E As SelectSet
E = b.SelectSet
If e.Count = 0 Then
Else
Dim i As Integer
i = 1
For Each c In e
i = i + 1
Next
'e.Name = ""
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 15
kresh.bell
Thanks a lot, now it's ok, it works.
Is it a big problem to add from the old iLogic this section:
If iProperties.Value ("Custom", "Prefix") = "" Then
iProperties.Value ("Custom", "Prefix") = iProperties.Value ("Project", "Part Number") & "_"
else
Message 12 of 15
bradeneuropeArthur
Your thanks are appreciated.
! Fo
r administrative reasons, please mark a "Solution as solved" when the issue is solved !
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 15
Biju.Veedu
Is here any ilogic to rename all solidbodies with a prefix on it? need want retain existing "body name" and want to add prefix to it.
for Example
" xxxxx_Solidbody 01"
" xxxxx_Solidbody 02"
" xxxxx_Solidbody 03"
thanks in advance.
Message 14 of 15
rclement
i see all these ilogic to rename solidbodies.i would like to see what the parameters look like if some one could take a snippit.
im sorry im really new to ilogic and i dont know what parameters need to be change
maybe theres a ilogic for dummies book
Message 15 of 15
Curtis_Waguespack
