iLogic: Remove Patterns with a QTY of 0
04:10 PM
I am trying to create a template assembly for a project that will require the rapid generation on 100's of similar conveyors made of modular pieces. Each will have a typical 5' drive assembly and a 5' tail assembly. For lengths of 20' and greater, a repeating pattern of 10' will be used. I've got the assembly work generate the appropriate number of 10' lengths based on whatever I specify as my overall length except when I need a length that is under 20'. This causes an issue with the pattern generating the 10' section as having a QTY of 0 and throws an error.
Is there an iLogic rule that could delete the assembly and 10' section when the QTY equals 0?
Thanks!
