iLogic - Refresh File from Vault
andrew_wade1
andrew_wade1
I am looking to make an iLogic rule similar to if your in the Vault tab and right click your file and get the options to refresh file. I want that translated to a button using ilogic. Thanks
vpeuvion
Try this :
ThisApplication.CommandManager.ControlDefinitions.Item("VaultRefresh").Execute
Hope this help.
Vincent.
g.georgiades
VaultRefresh will only refresh the status, it does not download the file. The actual command is
ThisApplication.CommandManager.ControlDefinitions.Item("RefreshRevision").Execute
You can figure out the internal command names using the Event Watcher Dev Tool included with the Inventor developer tools and manually performing the action you want.
Some third-party commands may not show up here - the best identifier is if there is a ribbon buttom for the third-party command.
andrew_wade1
That did not work, below is an image of the refresh file function i am looking for. My part file was changed from Released to WIP and will not check out unless i perform this function.
vpeuvion
Hi, ok can you try this :
ThisApplication.CommandManager.ControlDefinitions.Item("RefreshRevisionTop").Execute
 Vincent.
andrew_wade1
still did nothing.
