ilogic Part pattern supress
serpennica
serpennica
How would I suppress some of the occurrences in a Part "Sketch Driven Pattern"
is there an iLogic rule to work this.
bradeneuropeArthur
You don't need illogic for this!
you can do that inventor default.
Use parameters for this.
i.e.: Use a parameter distance "0"
and a parameter for the suppression of the component one.
read this also:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/210054325-Inventor-2017-quick-tip-Set-rules-to-...
In detail I can show you on Monday.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
