iLogic Parameter Issue - Inventor 2018.2.3
MattH_Work
MattH_Work
Can someone check this.
Open the attached Part (or create your own)
Using the following code, create an external rule
Run the rule
If Parameter("Thickness") = 6 Then
	MessageBox.Show(Parameter("Thickness"), "Thickness")
If Parameter("Width") = 10 Then
	MessageBox.Show(Parameter("Width"), "Width")
How come "Width" generates a MsgBox, but "Thickness" does not .
Note that the code works in an internal rule as expected
If Thickness = 6 Then
	MessageBox.Show(Thickness, "Thickness")
If Width = 10 Then
	MessageBox.Show(Width, "Width")
If I change the code to the following (adding  .ToString)  then the code works
If Parameter("Thickness").ToString = 6 Then
If Parameter("Width").ToString = 10 Then
It seems that the way Inventor reports/records a number to ther user is different to how it keeps the number internally
Regards
MattH
MattH
Product Design Collection 2026
Vault Pro 2026
bradeneuropeArthur
They are both defined as "object" that is why you need the .tostring!
If Parameter("Thickness") = 6 Then ' output as object
If Parameter("Width") = 10 Then ' output as object
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
