Ilogic not reading my Excell file.
JorisSteurs1246
Message 1 of 23
JorisSteurs1246
Does anyone has any clue why ilogic is not reading my excell file.
When I copy the path from the rule, it will open correctly when i paste it in file explorer.
Screenshots of error box are attached.
Ilogic below.
SyntaxEditor Code Snippet
'---------start of iLogic code---------
StartRule:'read excel file
GoExcel.Open("F:\JorisTest.xlsx")
'index row 2 through 100
For rowPN = 2 To 100
'find first empty cell in column B
 If (GoExcel.CellValue("B" & rowPN) = "") Then
'create a variable for the cell value that is one row less than 'the empty cell row
    lastPN = GoExcel.CellValue("B" & rowPN - 1)
      lastDesc = GoExcel.CellValue("C" & rowPN- 1)
         Exit For
Next
'show results and ask user to confirm results
question = MessageBox.Show("PN: " & lastPN & vbLf _
&"Description: " & lastDesc & vbLf _
& "Is this correct?", "iLogic from Excel", MessageBoxButtons.YesNo )
'if answer is no
If question = vbNo Then
Goto StartRule
'if answer is yes exit rule
Else End If
Replies (22)
Message 21 of 23
Vladimir.Ananyev
We definitely need the detailed description of your configuration to be able to investigate this case.
  • Windows, MS Office, Inventor (versions, including language settings).
  • dataset that could help to reproduce this error
Is it possible?
thanks
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 22 of 23
JorisSteurs1246
I'm in the proccess now of installing Windows 10 on my laptop to do the same test.
I tought this might be a good idea, as I understood the problem might be windows related.
If the new windows install will solve the problem, I'll install it also on my main CADstation.
Message 23 of 23
JorisSteurs1246
OK guys, sorry for not coming back earlier to you. It turned out to be a windows problem and I had to do a complete reinstall of the windows 7.
It took me some time obviously. I did the little test rule that was suggested earlier and now this works OK. The funny thing or rather strange coincident is that both laptop and desktop have this problem, so big maintenance ahead for the desktop also.
Thank you for all the support.
