Ilogic Not Matching If Test
rttechno
rttechno
I'm working on a simple bit of code that will allow me to change to a predetermined sheet metal style based on the existing thickness in a file.  My customer changed shops and I need to switch to the bend rads they have available.  I am just running the code in each file as I open them.  It works for every thickness except 12 GA. (.1046).  The parameter in the document is .1046 but it doesn't pass the IF test and execute the code within.  I'm sure it's something stupid but I can't find it...  Any ideas?
MessageBox.Show(Parameter("Thickness"), "Param Value")
If Parameter("Thickness") = .125
	SheetMetal.SetActiveStyle(".125 .125 Rad")
	MessageBox.Show(SheetMetal.GetActiveStyle, "Title")
Else If Parameter("Thickness") = .5
	SheetMetal.SetActiveStyle("1/2" & """" & " .2366 Rad")
Else If Parameter("Thickness") = .25
	SheetMetal.SetActiveStyle("1/4" & """" & " .1719 Rad")
Else If Parameter("Thickness") = .1046
	SheetMetal.SetActiveStyle("12 Ga .0781 Rad")
Else If Parameter("Thickness") = .1345
	SheetMetal.SetActiveStyle("10 Ga .125 Rad")
Else If Parameter("Thickness") = .0747
	SheetMetal.SetActiveStyle("14 Ga .0781 Rad")
Else If Parameter("Thickness") = .1875
	SheetMetal.SetActiveStyle("3/16" & """" & " .125 Rad")
Else If Parameter("Thickness") = .375
	SheetMetal.SetActiveStyle("3/8" & """" & " .1719 Rad")
Else If Parameter("Thickness") = .3125
	SheetMetal.SetActiveStyle("5/16" & """" & " .0781 Rad")
End If
RT Technologies
Autodesk Inventor 2017
Windows 10
Owner2229
Hey, my guess would be floating point numbers:
http://modthemachine.typepad.com/my_weblog/2013/08/comparing-floating-point-numbers.html
Try it like this:
Dim oVal As Double = Parameter("Thickness")
Dim oStyle As String = vbNullString
Select Case Math.Round(oVal, 4)
Case .125:		oStyle = ".125 .125 Rad"
Case .5:		oStyle = "1/2" & """" & " .2366 Rad"
Case .25:		oStyle = "1/4" & """" & " .1719 Rad"
Case .1046:		oStyle = "12 Ga .0781 Rad"
Case .1345:		oStyle = "10 Ga .125 Rad"
Case .0747:		oStyle = "14 Ga .0781 Rad"
Case .1875:		oStyle = "3/16" & """" & " .125 Rad"
Case .375:		oStyle = "3/8" & """" & " .1719 Rad"
Case .3125:		oStyle = "5/16" & """" & " .0781 Rad"
Case Else:	Exit Sub
End Select
SheetMetal.SetActiveStyle(oStyle)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
rttechno
Hi Mike,
Thanks for the quick response.  I'll give it a shot!
Randy
rttechno
Worked perfect.  Thanks so much!  What a weird issue...
