tracking objects after simulation
  I've been working on this C# code for a while, and I cannot make a head or a tail out of it. Basically, I would like to know the transforms of a series of objects after some simulation steps. For instance, imagine I have 3 connected gears, and I apply some rotation to the first one. What I would like to know is the rotation of the other two after the first one rotated a few degrees.
 For this, I am using C# with the following piece of code to retrieve the results (after the simulation has finished):
AssemblyDocument asmDoc = (AssemblyDocument)_invApp.ActiveDocument;
ComponentOccurrences g = asmDoc.ComponentDefinition.Occurrences;
SurfaceBodies sb = asmDoc.ComponentDefinition.SurfaceBodies;
foreach (SurfaceBody sby in sb)
   // doesn't seem to enter here, sb is empty!
foreach (ComponentOccurrence element in g)
     ComponentDefinition Defi = element.Definition;
     // I CAN do this, but I do not know how to go on after getting the definition...
 thanks in advance for any help!!!
 best
gus.-
I have the same problem, in c# I can't get the Angular velocity of a gear, any one have the solution?
   Someone, please!!! I am REALLY stuck with this!!! I haven't been able to add a single meaningful line to my code in weeks!!!
   If you have the solution to know the "current" state of a part, even if it is VB, I would LOVE to hear it!!!
   please!!
   best
gus.-
