ilogic menu
ilogic menu
ilogic menu
I'm playing with iLogic and thought as simple making a rule. I have a hole in a large panel which I want to send through a menu. For each code is a different diameter. If I change the parameter then  the hole stays the same. Do I missing something?
If sparing = DN100 Then
maat_ØH = 122
ElseIf sparing = DN125 Then
maat_ØH = 152
ElseIf sparing = DN160 Then
maat_ØH = 194
Mike.Wohletz
The problem with what you have is that you are wanting to check a string value and yet your actually declaring a variable since it is not in parentheses, see below corrected code.
If sparing = "DN100" Then
maat_ØH = 122
ElseIf sparing = "DN125" Then
maat_ØH = 152
ElseIf sparing = "DN160" Then
maat_ØH = 194
Mike,
Thanks, its the litle things who make the solution.
