Changing Circular Pattern Orientation with iLogic
josephcooley
Message 1 of 12
josephcooley
Does anyone know if there is a way to change the Orientation of a circular pattern with iLogic?
Replies (11)
Message 2 of 12
Curtis_Waguespack
Hi josephcooley,
Here is a quick example (see the attached file also).
I hope this helps.
Curtis
app = ThisApplication
'flip rectangular pattern direction
if Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection  = True then
Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection  = False
Else Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection  = True
End if
'flip circular pattern direction
if Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection  = True then
Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection  = False
Else Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection  = True
End if
Message 3 of 12
josephcooley
Hi Long time no post but it looks like something has stopped working with this rule in the new release for some reason.
SyntaxEditor Code Snippet
If Orientation="CW" Then
Feature.InventorFeature("NubPattern").NaturalAxisDirection = True 'flip circular pattern direction
Else If Orientation="CCW"
Feature.InventorFeature("Pattern").NaturalAxisDirection = False 'flip circular pattern direction
Its giving me this Error Message
Error in rule: Orientation, in document: Headcell3DesignTool.ipt
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
And this is on the More Info Tab
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any idea why this rule would have stopped working suddenly with the new release, or if there is a new syntax that needs to be used in Inventor 2018?
Message 4 of 12
josephcooley
How would I do this same thing for an assembly?  For a circular pattern with parts instead of features.
Message 5 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@josephcooley,
Try below iLogic code to change orientation of circular pattern.
For Part Document:
Dim doc = ThisDoc.Document
Dim oDef As PartComponentDefinition
oDef = doc.ComponentDefinition
If oDef.Features.CircularPatternFeatures.Item("Circular Pattern1").NaturalAxisDirection = False Then
	oDef.Features.CircularPatternFeatures.Item("Circular Pattern1").NaturalAxisDirection = True
Else
For Assembly Document:
Dim oDoc = ThisDoc.Document
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oPattern As CircularOccurrencePattern
oPattern = oDef.OccurrencePatterns.Item("Component Pattern 1:1")
If oPattern.AxisEntityNaturalDirection = True Then
	oPattern.AxisEntityNaturalDirection = False
Else
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 6 of 12
josephcooley
This worked for one assembly but I have a circular pattern nested within a linear pattern in another assembly and its not working correctly. its giving me this message below:
Error Message:
Error in rule: Orientation, in document: Tray Stack, Bottom_HC3.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
More Info
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OccurrencePatterns.get_Item(Object Index)
I have attached a screenshot of the model tree structure.  The "rotational pattern" is the one I want to switch within the "Linear Pattern"
Here is the code:
trigger = OrientationNumeric
oPattern = oDef.OccurrencePatterns.Item("Rotational Pattern")
If OrientationNumeric = 0 Then
Else
Message 7 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@josephcooley,
Unfortunately, nested CircularOccurrencePattern is unable to list in OccurrencePatterns Object. So, a change request (INVGEN - 13017) is raised on this.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@josephcooley,
For nested circular pattern, needs some changes in iLogic code. Try the below iLogic code.
Sub Main()
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oTopPattern As OccurrencePattern
    oTopPattern = oDef.OccurrencePatterns(1)
    Dim oPatternElement As OccurrencePatternElement
    oPatternElement = oTopPattern.OccurrencePatternElements(1)
    Dim oSubPattern As OccurrencePattern
    oSubPattern = oPatternElement.Components(1)
	If oSubPattern.AxisEntityNaturalDirection = True Then
		oSubPattern.AxisEntityNaturalDirection = False
	Else
End Sub
If solves problem, click on "accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 12
josephcooley
That worked Perfectly Thank you!
Message 10 of 12
josephcooley
@chandra.shekar.g
Looks like I spoke too soon.  It triggers fine when I run the rule exclusively when that assembly is open.  However that assembly is in another top level assembly.  I have it set to trigger the rule before save.
here is the code text:
Sub Main()
	Else
End Sub
The problem is that I want it to run when I save the Top level asembly each sub assmebly that the above rule is in gives me this:
ERROR MESSAGE:
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.OccurrencePattern'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{09A5CE88-D529-499E-82EF-246D8DC4F5B3}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
MORE INFO:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.OccurrencePattern'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{09A5CE88-D529-499E-82EF-246D8DC4F5B3}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Any idea why the rule would run fine when it was executed from the assembly the rule is in, but when its run as a result of the top level assembly being saved trigger an error?
Message 11 of 12
chandra.shekar.g
Autodesk Support
Autodesk Support
@josephcooley,
My apologies for late reply.
Try the below iLogic code. oDoc = ThisApplication.ActiveDocument represents top level assembly not sub assembly. Searching for OccurencePattern in main assembly or top level assembly. Instead of this, oDoc = ThisDoc.Document would solve the issue.
Sub Main()
If OrientationNumeric = 1 Then
Else
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 12
That was exactly what the problem was.  Thank you again so much.  You really saved me here. Works Flawlessly!
