Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Does anyone know if there is a way to change the Orientation of a circular pattern with iLogic?
Hi josephcooley,
Here is a quick example (see the attached file also).
I hope this helps.
Curtis
app = ThisApplication 'flip rectangular pattern direction if Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection = True then Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection = False Else Feature.InventorFeature("Rectangular Pattern1").NaturalXDirection = True End if 'flip circular pattern direction if Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection = True then Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection = False Else Feature.InventorFeature("Circular Pattern1").NaturalAxisDirection = True End if
Hi Long time no post but it looks like something has stopped working with this rule in the new release for some reason.
SyntaxEditor Code Snippet
app = ThisApplication If Orientation="CW" Then Feature.InventorFeature("NubPattern").NaturalAxisDirection = True 'flip circular pattern direction Else If Orientation="CCW" Feature.InventorFeature("Pattern").NaturalAxisDirection = False 'flip circular pattern direction End If
Its giving me this Error Message
Error in rule: Orientation, in document: Headcell3DesignTool.ipt
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
And this is on the More Info Tab
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.InternalLateSet(Object o, Type& objType, String name, Object[] args, String[] paramnames, Boolean OptimisticSet, CallType UseCallType)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateSet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean OptimisticSet, Boolean RValueBase, CallType CallType)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any idea why this rule would have stopped working suddenly with the new release, or if there is a new syntax that needs to be used in Inventor 2018?
How would I do this same thing for an assembly? For a circular pattern with parts instead of features.
Try below iLogic code to change orientation of circular pattern.
For Part Document:
Dim doc = ThisDoc.Document Dim oDef As PartComponentDefinition oDef = doc.ComponentDefinition If oDef.Features.CircularPatternFeatures.Item("Circular Pattern1").NaturalAxisDirection = False Then oDef.Features.CircularPatternFeatures.Item("Circular Pattern1").NaturalAxisDirection = True Else oDef.Features.CircularPatternFeatures.Item("Circular Pattern1").NaturalAxisDirection = False End If
For Assembly Document:
Dim oDoc = ThisDoc.Document Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition Dim oPattern As CircularOccurrencePattern oPattern = oDef.OccurrencePatterns.Item("Component Pattern 1:1") If oPattern.AxisEntityNaturalDirection = True Then oPattern.AxisEntityNaturalDirection = False Else oPattern.AxisEntityNaturalDirection = True End If
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
This worked for one assembly but I have a circular pattern nested within a linear pattern in another assembly and its not working correctly. its giving me this message below:
Error Message:
Error in rule: Orientation, in document: Tray Stack, Bottom_HC3.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
More Info
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.OccurrencePatterns.get_Item(Object Index)
I have attached a screenshot of the model tree structure. The "rotational pattern" is the one I want to switch within the "Linear Pattern"
Here is the code:
trigger = OrientationNumeric Dim oDoc = ThisDoc.Document Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition Dim oPattern As CircularOccurrencePattern oPattern = oDef.OccurrencePatterns.Item("Rotational Pattern") If OrientationNumeric = 0 Then oPattern.AxisEntityNaturalDirection = False Else oPattern.AxisEntityNaturalDirection = True End If
Unfortunately, nested CircularOccurrencePattern is unable to list in OccurrencePatterns Object. So, a change request (INVGEN - 13017) is raised on this.
Thanks and regards,
For nested circular pattern, needs some changes in iLogic code. Try the below iLogic code.
Sub Main() Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition Dim oTopPattern As OccurrencePattern oTopPattern = oDef.OccurrencePatterns(1) Dim oPatternElement As OccurrencePatternElement oPatternElement = oTopPattern.OccurrencePatternElements(1) Dim oSubPattern As OccurrencePattern oSubPattern = oPatternElement.Components(1) If oSubPattern.AxisEntityNaturalDirection = True Then oSubPattern.AxisEntityNaturalDirection = False Else oSubPattern.AxisEntityNaturalDirection = True End If End Sub
If solves problem, click on "accept as solution" / give a "Kudo".
Thanks and regards,
That worked Perfectly Thank you!
Looks like I spoke too soon. It triggers fine when I run the rule exclusively when that assembly is open. However that assembly is in another top level assembly. I have it set to trigger the rule before save.
here is the code text:
Sub Main() Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition oDef = oDoc.ComponentDefinition Dim oTopPattern As OccurrencePattern oTopPattern = oDef.OccurrencePatterns(1) Dim oPatternElement As OccurrencePatternElement oPatternElement = oTopPattern.OccurrencePatternElements(1) Dim oSubPattern As OccurrencePattern oSubPattern = oPatternElement.Components(1) If OrientationNumeric = 0 Then oSubPattern.AxisEntityNaturalDirection = False Else oSubPattern.AxisEntityNaturalDirection = True End If End Sub
The problem is that I want it to run when I save the Top level asembly each sub assmebly that the above rule is in gives me this:
ERROR MESSAGE:
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.OccurrencePattern'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{09A5CE88-D529-499E-82EF-246D8DC4F5B3}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
MORE INFO:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.OccurrencePattern'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{09A5CE88-D529-499E-82EF-246D8DC4F5B3}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Any idea why the rule would run fine when it was executed from the assembly the rule is in, but when its run as a result of the top level assembly being saved trigger an error?
My apologies for late reply.
Try the below iLogic code. oDoc = ThisApplication.ActiveDocument represents top level assembly not sub assembly. Searching for OccurencePattern in main assembly or top level assembly. Instead of this, oDoc = ThisDoc.Document would solve the issue.
Sub Main()
If OrientationNumeric = 1 Then
Else
End If
End Sub
Thanks and regards,
That was exactly what the problem was. Thank you again so much. You really saved me here. Works Flawlessly!
