Ilogic library
Ilogic library
Ilogic library
I am wondering if there is a place where I can download ilogic examples that I can apply to my designs?
I hope to learn the code but would like to see if ilogic can immediately benefit my workflow.
I see there are some at grabcad, are there any other places out there?
Thanks in advance.
MechMachineMan
Have you heard of the search functionality?
Type in your problem in google with "autodesk inventor customization + " and then search and you're almost certain to get hits of solved problems.
Another fellow was also just posting samples on the forums here over the last week.
There are also many blogs out there.
modthemachine,
InTheTrenches,
etc.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rhasell
Hi
@S_May has just posted some handy examples, maybe these can be of some help to you on your journey.
https://forums.autodesk.com/t5/inventor-forum/collection-of-ilogic-models-for-beginner/m-p/7334541#M...
Reg
2026.1
