ilogic initial values
gi
Message 1 of 15
gi
In assembly I have steel plates put together. Every plate could be max. 2000 mm lenght, and assembly is made from max. 10 plates. In form at the begining I want write total lenght of assembly. Depending on that value rule in iLogic should initially set how many pieces of plates is used and their lenght. Let's say that initially every plate lenght should be 1500 mm besides last one, which is the difference between the total width and the sum of the width of all other plates.
Later I want manually set quantity of plates and their lenght individually. Is there a code in iLogic to do this?
Below is example of assembly.
Replies (14)
Message 2 of 15
clutsa
Here's what I come up with...
Dim app As Inventor.Application = ThisApplication
Dim doc As Document = app.ActiveDocument
inc = 1 ' rounding increment ( .125, .25, .5, etc)
'Clear all panels
For i = 1 To 10
	Parameter("Panel" & i) = 0
Next
'figure how many panels you need
Panels = Ceil(Round(Length / PanelStandardWidth, 1) / inc) * inc
If Panels > MaxPanelCount Then Panels = MaxPanelCount
TempWidth = Panels * PanelStandardWidth
'MessageBox.Show("TempWidth = " & TempWidth, "Title")
Parameter("LastPanelWidth") = PanelStandardWidth - (TempWidth - Parameter("Length"))
'MessageBox.Show("LastPanelWidth = " & Parameter("LastPanelWidth"), "Title")
If Parameter("LastPanelWidth") > MaxPanelWidth Then
	'MessageBox.Show("Odd Size", "Title")
	For i = 1 To Panels
		If Parameter("LastPanelWidth") > MaxPanelWidth Then 'max out first panels until last panel fits
			Parameter("Panel" & i) = MaxPanelWidth
			Parameter("LastPanelWidth") = Parameter("LastPanelWidth") - (MaxPanelWidth - PanelStandardWidth)
		Else
			If i <> Panels Then 'check for last panel
				Parameter("Panel" & i) = PanelStandardWidth
			Else
				Parameter("Panel" & i) = Parameter("LastPanelWidth")
			End If
		End If
	Next
Else
	'MessageBox.Show("Standard", "Title")
	For i = 1 To Panels
		Else
		End If
	Next
End If
PanelSum = Parameter("Panel1") + Parameter("Panel2") + Parameter("Panel3") + Parameter("Panel4") + Parameter("Panel5") + Parameter("Panel6") + Parameter("Panel7") + Parameter("Panel8") + Parameter("Panel9") + Parameter("Panel10")
'MessageBox.Show("PanelSum = " & PanelSum, "Title")
Your Parameters will look something like
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 15
gi
Setting initial values based on Overall length works fine, but later when I want set individual Panel width then it's not quite works. Below is my code. I changed names according to my schema. I know that I have changed the width limit only for the number of panels equal to 10, but I only try to test it only for that configuration. How make to run initial rule only after changing parameter "Length" or "Długość_Lw" acording to my name? After that I want change Panels Width (Szerokość_płaszcza_wewn) manually.
'Clear all panels
For i = 1 To 10
	Parameter("Szerokość_płaszcza_wewn_" & i) = 0
Next
'figure how many płaszczy wewnętrznych you need
Ilosc_płaszczy_wewn = Ceil(Round(Długość_Lw / Plaszcz_wewn_standard_szer, 1) / inc) * inc
If Ilosc_płaszczy_wewn > Max_ilosc_plaszczy_wewn Then Ilosc_płaszczy_wewn = Max_ilosc_plaszczy_wewn
TempWidth = Ilosc_płaszczy_wewn * Plaszcz_wewn_standard_szer
Parameter("Plaszcz_wewn_dodatk_szer") = Plaszcz_wewn_standard_szer - (TempWidth - Parameter("Długość_Lw"))
'MessageBox.Show("Plaszcz_wewn_dodatk_szer = " & Parameter("Plaszcz_wewn_dodatk_szer"), "Title")
If Parameter("Plaszcz_wewn_dodatk_szer") > Plaszcz_wewn_max_szer Then
	For i = 1 To Ilosc_płaszczy_wewn
		If Parameter("Plaszcz_wewn_dodatk_szer") > Plaszcz_wewn_max_szer Then 'max out first panels until last panel fits
			Parameter("Szerokość_płaszcza_wewn_" & i) = Plaszcz_wewn_max_szer
			Parameter("Plaszcz_wewn_dodatk_szer") = Parameter("Plaszcz_wewn_dodatk_szer") - (Plaszcz_wewn_max_szer - Plaszcz_wewn_standard_szer)
		Else
			If i <> Ilosc_płaszczy_wewn Then 'check for last panel
				Parameter("Szerokość_płaszcza_wewn_" & i) = Plaszcz_wewn_standard_szer
			Else
				Parameter("Szerokość_płaszcza_wewn_" & i) = Parameter("Plaszcz_wewn_dodatk_szer")
			End If
		End If
	Next
Else
		Else
		End If
	Next
End If
Suma_szer_plaszczy_wewn = Parameter("Szerokość_płaszcza_wewn_1") + Parameter("Szerokość_płaszcza_wewn_2") + Parameter("Szerokość_płaszcza_wewn_3") + Parameter("Szerokość_płaszcza_wewn_4") + Parameter("Szerokość_płaszcza_wewn_5") + Parameter("Szerokość_płaszcza_wewn_6") + Parameter("Szerokość_płaszcza_wewn_7") + Parameter("Szerokość_płaszcza_wewn_8") + Parameter("Szerokość_płaszcza_wewn_9") + Parameter("Szerokość_płaszcza_wewn_10")
'MessageBox.Show("Suma szerokości płaszczy wewn. = " & Suma_szer_plaszczy_wewn, "Title")
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
Try
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("iLogic").Activate(True)
Catch
Dim nLOD As LevelOfDetailRepresentation
nLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("iLogic")
oLOD = nLOD
Finally
End Try
If Ilosc_płaszczy_wewn = 1 Then
	Component.IsActive("Płaszcz wewn. X:1") = False
	Płaszcz_wewn_10 = False
	Component.IsActive("Płaszcz wewn. IX:1") = False
	Płaszcz_wewn_9 = False
	Component.IsActive("Płaszcz wewn. VIII:1") = False
	Płaszcz_wewn_8 = False
	Component.IsActive("Płaszcz wewn. VII:1") = False
	Płaszcz_wewn_7 = False
	Component.IsActive("Płaszcz wewn. VI:1") = False
	Płaszcz_wewn_6 = False
	Component.IsActive("Płaszcz wewn. V:1") = False
	Płaszcz_wewn_5 = False
	Component.IsActive("Płaszcz wewn. IV:1") = False
	Płaszcz_wewn_4 = False
	Component.IsActive("Płaszcz wewn. III:1") = False
	Płaszcz_wewn_3 = False
	Component.IsActive("Płaszcz wewn. II:1") = False
	Płaszcz_wewn_2 = False
	Component.IsActive("Płaszcz wewn. I:1") = True
	Płaszcz_wewn_1 = True
Parameter("Płaszcz wewn. I:1", "Szerokość") = Długość_Lw
ElseIf Ilosc_płaszczy_wewn = 2 Then
	Component.IsActive("Płaszcz wewn. II:1") = True
	Płaszcz_wewn_2 = True
Parameter("Płaszcz wewn. I:1", "Szerokość") = Szerokość_płaszcza_wewn_1
Szerokość_płaszcza_wewn_2 = Długość_Lw - Szerokość_płaszcza_wewn_1
Parameter("Płaszcz wewn. II:1", "Szerokość") = Szerokość_płaszcza_wewn_2
ElseIf Ilosc_płaszczy_wewn = 3 Then
	Component.IsActive("Płaszcz wewn. III:1") = True
	Płaszcz_wewn_3 = True
Szerokość_płaszcza_wewn_3 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2
Parameter("Płaszcz wewn. III:1", "Szerokość") = Szerokość_płaszcza_wewn_3
ElseIf Ilosc_płaszczy_wewn = 4 Then
	Component.IsActive("Płaszcz wewn. IV:1") = True
	Płaszcz_wewn_4 = True
Szerokość_płaszcza_wewn_4 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3
Parameter("Płaszcz wewn. IV:1", "Szerokość") = Szerokość_płaszcza_wewn_4
ElseIf Ilosc_płaszczy_wewn = 5 Then
	Component.IsActive("Płaszcz wewn. V:1") = True
	Płaszcz_wewn_5 = True
Szerokość_płaszcza_wewn_5 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4
Parameter("Płaszcz wewn. V:1", "Szerokość") = Szerokość_płaszcza_wewn_5
ElseIf Ilosc_płaszczy_wewn = 6 Then
	Component.IsActive("Płaszcz wewn. VI:1") = True
	Płaszcz_wewn_6 = True
Szerokość_płaszcza_wewn_6 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4 - Szerokość_płaszcza_wewn_5
Parameter("Płaszcz wewn. VI:1", "Szerokość") = Szerokość_płaszcza_wewn_6
ElseIf Ilosc_płaszczy_wewn = 7 Then
	Component.IsActive("Płaszcz wewn. VII:1") = True
	Płaszcz_wewn_7 = True
Szerokość_płaszcza_wewn_7 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4 - Szerokość_płaszcza_wewn_5 - Szerokość_płaszcza_wewn_6
Parameter("Płaszcz wewn. VII:1", "Szerokość") = Szerokość_płaszcza_wewn_7
ElseIf Ilosc_płaszczy_wewn = 8 Then
	Component.IsActive("Płaszcz wewn. VIII:1") = True
	Płaszcz_wewn_8 = True
Szerokość_płaszcza_wewn_8 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4 - Szerokość_płaszcza_wewn_5 - Szerokość_płaszcza_wewn_6 - Szerokość_płaszcza_wewn_7
Parameter("Płaszcz wewn. VIII:1", "Szerokość") = Szerokość_płaszcza_wewn_8
ElseIf Ilosc_płaszczy_wewn = 9 Then
	Component.IsActive("Płaszcz wewn. IX:1") = True
	Płaszcz_wewn_9 = True
Szerokość_płaszcza_wewn_9 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4 - Szerokość_płaszcza_wewn_5 - Szerokość_płaszcza_wewn_6 - Szerokość_płaszcza_wewn_7 - Szerokość_płaszcza_wewn_8
Parameter("Płaszcz wewn. IX:1", "Szerokość") = Szerokość_płaszcza_wewn_9
ElseIf Ilosc_płaszczy_wewn = 10 Then
	Component.IsActive("Płaszcz wewn. X:1") = True
	Płaszcz_wewn_10 = True
	Szerokość_płaszcza_wewn_10 = Długość_Lw - Szerokość_płaszcza_wewn_1 - Szerokość_płaszcza_wewn_2 - Szerokość_płaszcza_wewn_3 - Szerokość_płaszcza_wewn_4 - Szerokość_płaszcza_wewn_5 - Szerokość_płaszcza_wewn_6 - Szerokość_płaszcza_wewn_7 - Szerokość_płaszcza_wewn_8 -Szerokość_płaszcza_wewn_9
			If Szerokość_płaszcza_wewn_10 > Plaszcz_wewn_max_szer Then
		Szerokość_płaszcza_wewn_10 = Plaszcz_wewn_max_szer
		Parameter("Płaszcz wewn. X:1", "Szerokość") = Szerokość_płaszcza_wewn_10
	End If
End If
Message 4 of 15
clutsa
In the rule editor there are tabs at the top. Open the "Options" tab and check the "Don't run automatically" button.  This will stop the rule from running when it wants. You can then run the rule manually from the iLogic browser or you can add
trigger = iTrigger0
To the top of your rule and it will run when you click the "iTrigger" button in the "iLogic" section under the "Manage" Tab
Message 5 of 15
gi
You probably misunderstand me. First I want initially set panels width (Szerokość_płaszcza_wewn) depending on Overall Lenght "Długość_Lw". It's 16400 mm on drawing from first message. That parameter is set first in the form by user. When user change value of this parameter then all panels widths are set to default value - 1500 mm or 2000 mm, except last one. That is working fine. Code from message nr.2 by clutsa do it perfect. But next step will be setting panels widths individually. Only sum should not change and width of every panel should not exceed 2000 mm. So initial code from message 2 should be omitted, when user change only individual panel width. I suppose it could be done using Case Select. How it could be done?
Message 6 of 15
clutsa
I might need some examples... from post 2:  panel1 and panel2 are 2000 then everything is 1500 except panel 10 is 1900. If the user changes panel3 from 1500 to 1800 you want panel10 to go from 1900 to 1600?
What needs to happen if the user changes panel3 from 1500 to 1300? Will panel10 go to 2100 and throw an error message?
Message 7 of 15
gi
My first message and drawing from this message is just example. User change panel width in sequence from first to last panel, because in assembly there are other parts which can't be placed on connection between panels only on the panel. If user change one of panels then last one (panel10) should change, but not exceed 2000 mm. If that happen then panel9 should change. Of course it can't exceed 2000 mm either. If that's not enough then panel8 change it's width, and go on. Error message it's not necessary. I prefer changing width automatically in accordance with the wide limit.
Message 8 of 15
clutsa
I added a parameter named "CalculatedLength"
'setting these variables will trigger the rule to run
tempVar = Panel1
tempVar = Panel2
tempVar = Panel3
tempVar = Panel4
tempVar = Panel5
tempVar = Panel6
tempVar = Panel7
tempVar = Panel8
tempVar = Panel9
tempVar = Panel10
If Length <> CalculatedLength Then 'if the length is different from the last time code ran, run a full overhaul
	'MessageBox.Show("Full overhaul", "Title")
	'Clear all panels
	For i = 1 To 10
	Next
		For i = 1 To Panels
			Else
				Else
				End If
			End If
		Next
	Else
		For i = 1 To Panels
			Else
			End If
		Next
	End If
	CalculatedLength = Parameter("Panel1") + Parameter("Panel2") + Parameter("Panel3") + Parameter("Panel4") + Parameter("Panel5") + Parameter("Panel6") + Parameter("Panel7") + Parameter("Panel8") + Parameter("Panel9") + Parameter("Panel10")
Else 'only a panel width changed so do this code instead
	Count = 0
	'MessageBox.Show("Small changes", "Title")
	Delta = Length - PanelSum
	Parameter("Panel" & Panels) = Parameter("Panel" & Panels) + Delta
	Do Until Parameter("Panel" & Panels - Count) < MaxPanelWidth Or InfCount > 100
		If Parameter("Panel" & Panels - Count) > MaxPanelWidth Then
			Delta = Parameter("Panel" & Panels - Count) - MaxPanelWidth
			Parameter("Panel" & Panels - Count) = Parameter("Panel" & Panels - Count) - Delta
			Parameter("Panel" & Panels - Count - 1) = Parameter("Panel" & Panels - Count - 1) + Delta
			Count = Count + 1
		End If
		InfCount = InfCount + 1
	Loop
End If
'An idea on how to change your parts too
Dim p1 = Component.InventorComponent("SHEETMETAL:1")
Dim p2 = Component.InventorComponent("SHEETMETAL:2")
Dim p3 = Component.InventorComponent("SHEETMETAL:3")
Dim p4 = Component.InventorComponent("SHEETMETAL:4")
Dim p5 = Component.InventorComponent("SHEETMETAL:5")
Dim p6 = Component.InventorComponent("SHEETMETAL:6")
Dim p7 = Component.InventorComponent("SHEETMETAL:7")
Dim p8 = Component.InventorComponent("SHEETMETAL:8")
Dim p9 = Component.InventorComponent("SHEETMETAL:9")
Dim p10 = Component.InventorComponent("SHEETMETAL:10")
Dim PanelList As New ArrayList
PanelList.Add(p1)
PanelList.Add(p2)
PanelList.Add(p3)
PanelList.Add(p4)
PanelList.Add(p5)
PanelList.Add(p6)
PanelList.Add(p7)
PanelList.Add(p8)
PanelList.Add(p9)
PanelList.Add(p10)
'code to change LOD here if needed
For i = 1 To 10
	If Parameter("Panel" & i) < 1 Then
		PanelList(i - 1).Excluded = True 'you can use isActive() instead
	Else
		PanelList(i - 1).Excluded = False 'you can use isActive() instead
		Parameter(PanelList(i - 1).name, "d0") = Parameter("Panel" & i)
	End If
Next
InventorVb.DocumentUpdate()
Message 9 of 15
gi
Initilal setup works fine. When I change overall lenght width of every panel also change, but when I try change width of a individual panel then it go back to previous value and nothing happen. Besides at the end of rule you use paramater d0. I suppose it should refer to width of a panel?
Else
	End If
Message 10 of 15
clutsa
Yes, please change "d0" to the name of the parameter in the panels that controls their width (probably "Szerokość".) Make sure you change the parameter name in each of the panels to the same name (as it looks like you have.)
When you say "when I try change width of a individual panel then it go back to previous value and nothing happen." can you give me an example of which panel and what it's old value was and what you're trying to change it to? In the 16400 length example if you change panel4 from 1500 to 1300 then panel10 should change from 1900 to 2000 and panel9 should change from 1500 to 1600.
Please note that in my screen capture below the  actual panel widths don't change because I only inserted the same part 10 times so please only read the values in parameter and count how many panels are there total.
Message 11 of 15
gi
Ok. I didn't change one parameter according to my naming schema in a rule. That's why it didn't work. Now it's working almost great ;). Probably there will be situation when also quantity of panels should be changed. How rule should be changed to do this?
I also have another panel position variant which you could solved. Every panel are 1500 mm wide in this case, but they are overlap. Overlap is 50 mm. Only overall widht is changing and placing of the rest (LastPanelWidht in previous scenario) is also changing. I mean narrower panel could be placed as a last panel, but also could be placed as every panel from 1 to 12 in this case.
Below example of assembly. 450 mm wide panel is last, but as I mention it could be placed everywhere. User should choose which it should be.PANELS 2.jpg
Message 12 of 15
clutsa
You would of course add the extra panels to your parameters and add a new parameter named PanelOverlap.
Then the code would look something like this.
tempVar = Panel1
tempVar = Panel2
tempVar = Panel3
tempVar = Panel4
tempVar = Panel5
tempVar = Panel6
tempVar = Panel7
tempVar = Panel8
tempVar = Panel9
tempVar = Panel10
tempVar = Panel11
tempVar = Panel12
If Length <> CalculatedLength Then 'if the length is different from the last time code ran run a full overhaul
	'Clear all panels
	For i = 1 To MaxPanelCount
	Next
	Panels = Ceil(Round((Length - PanelOverlap) / (PanelStandardWidth - PanelOverlap), 1) / inc) * inc
	TempWidth = Panels * (PanelStandardWidth - PanelOverlap)
	Parameter("LastPanelWidth") = Int(PanelStandardWidth - (TempWidth - Parameter("Length")) - PanelOverlap)
		For i = 1 To Panels
			Else
				Else
				End If
			End If
		Next
	Else
		For i = 1 To Panels
			Else
			End If
		Next
	End If
	CalculatedLength = Parameter("Panel1") + Parameter("Panel2") + Parameter("Panel3") + Parameter("Panel4") + Parameter("Panel5") + Parameter("Panel6") + Parameter("Panel7") + Parameter("Panel8") + Parameter("Panel9") + Parameter("Panel10") + Parameter("Panel11") + Parameter("Panel12") - ((Panels - 1) * PanelOverlap)
	Count = 0
	PanelSum = Parameter("Panel1") + Parameter("Panel2") + Parameter("Panel3") + Parameter("Panel4") + Parameter("Panel5") + Parameter("Panel6") + Parameter("Panel7") + Parameter("Panel8") + Parameter("Panel9") + Parameter("Panel10") + Parameter("Panel11") + Parameter("Panel12") - ((Panels - 1) * PanelOverlap)
			Count = Count + 1
		End If
	Loop
End If
'An idea on how to change the parts too
Dim p11 = Component.InventorComponent("SHEETMETAL:11")
Dim p12 = Component.InventorComponent("SHEETMETAL:12")
PanelList.Add(p1)
PanelList.Add(p2)
PanelList.Add(p3)
PanelList.Add(p4)
PanelList.Add(p5)
PanelList.Add(p6)
PanelList.Add(p7)
PanelList.Add(p8)
PanelList.Add(p9)
PanelList.Add(p10)
PanelList.Add(p11)
PanelList.Add(p12)
	Else
	End If
Next
Message 13 of 15
gi
Everything works ok, but as I wrote in previous message I also need to choose where will be narrower panel  (LastPanelWidth). It isn't always last. User need to choose which one it will be from 1 to 12. Also how did you learn advanced ilogic commands? I know that this is Visual Basic, but besides this forum and Inventor API help is there a books or websites in the internet with examples explaining programming language commands?
Message 14 of 15
clutsa
I learned to program starting with VBA for Excel. Most of what I've learned for Inventor has been from this forum, API help, and just trail and error (lots of error) . Brian Ekins and Adam Nagy (both of whom help on this forum) have an amazing blog at https://modthemachine.typepad.com/ I also often point beginners to https://www.youtube.com/watch?v=MFU_QaGdIDA I think the video does a good job explaining how to use the "locals window" (a key skill to figuring out how and what Inventor is doing)
As far as moving where the short panel is I suggest you open a new topic on the forum for ideas. The original question was "ilogic initial values" and I feel you have that answered. If I remember you were going to have the user enter different values for each panel width later anyway. Couldn't they just type the last panel width in where they want it?
Message 15 of 15
gi
You're right. The initial topic has been resolved. Version with panels which overlap one another and how place narrower panel l solved myself. Thank you for help and information where to learn more about ilogic and Visual Basic 🙂
