iLogic initial directory in 2017 doesnt work
I got this code here in inventor forum. Modified the initial directory to go directly where the part was saved. It works fine in Inventor 2020 but not in 2017.
Sub Main()
Dim oDoc As DrawingDocument = ThisDoc.Document
oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
If oView Is Nothing Then Exit Sub
oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
oModelLength = oModelDoc.Length
'oModelPN = iProperties.Value(oModelDoc, "Project", "Part Number") 'MessageBox.Show(x, "oModelDoc")
oFullFilename = oView.ReferencedDocumentDescriptor.ReferencedDocument.fullfilename
oInitDir = Left(oFullFilename, Len(oFullFilename) -oModelLength)
'MessageBox.Show(oFullFilename, "Title")'MessageBox.Show(oInitDir, "Title")
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
oFileDlg.DialogTitle = "Select a File"
'oFileDlg.InitialDirectory = ThisDoc.Path
oFileDlg.InitialDirectory = oInitDir ' this is my additional code
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If oFileDlg.FileName = "" Then Exit Sub
NewFullFilename = oFileDlg.FileName
    Call ReplaceFileReference(oDoc, oFullFilename, NewFullFilename)
    iLogicVb.UpdateWhenDone = True
End Sub
Sub ReplaceFileReference(oDoc As Document, oRefToRemove As String, oRefToInclude As String)
    For Each oFD In oDoc.File.ReferencedFileDescriptors
        If oFD.FullFileName = oRefToRemove
             oFD.ReplaceReference(oRefToInclude)
    Next
End Sub
JhoelForshav
Thank you @JhoelForshav .
