Question about "Place ilogic component"
robertast
robertast
When you use the Place ilogic component, the name (Bushing-01.ipt) is appended with the suffix -01, -02, -03, ....
How to set the prefix "01-Bushing.ipt" to be added?
I could not find such a setting...
robertast
I don’t seem to be able to do that under normal circumstances.
@bradeneuropeArthur  , @johnsonshiue  In such situations, you can quickly find the answer. Maybe some things can be changed in .dll?
It suits me to always have a "01-Bushing.ipt"
Out of the box Inventor uses suffix -01, -02, -03, ....
I have not seen any settings that allow this to be changed.
BUT, if you use Vault and have a numbering scheme setup you can re-number the component, as shown in my video below.
https://autode.sk/2EjIkOd
robertast
Thanks  @Anonymous    I also didn't find such a feature so I asked here, maybe I didn't notice anything. But it looks like there is no such thing as normal access to it through and the API. Vault is not with me, I will have to look for some other solution. Reeks to explain the possibilities of the Design copy API.
Or maybe you already know about them?
