File Dialog Initial Directory stuck on workspace
yvandelafontaine
Message 1 of 14
yvandelafontaine
For Some Reason when I try to force a specific path in a file open dialog, inventor point toward the workspace every time
any reason or solution?
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = "C:\"
oFileDlg.CancelError = True
oFileDlg.Filter = "Excel Files (*.xls;*.xlsx;*.xlsm)|*.xls;*.xlsx;*.xlsm"
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfile = oFileDlg.FileName
MessageBox.Show("You selected: " & selectedfile , "iLogic")
Replies (13)
Message 2 of 14
BrandonBG
I didn't verify this, but does your project (*.ipj) show "C:\" as a Frequently Used Subfolder or the Workspace folder?
Brandon
Message 3 of 14
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi yvandelafontaine,
FileDialog.InitialDirectory is ignored if assembly or part is open. Inventor engineering team knows about this issue.
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 14
pball
@chandra.shekar.g
I just ran into the same issue and created a thread about it before seeing this one. There are a few more details also, like the file name property also does not work.
https://forums.autodesk.com/t5/inventor-customization/inventor-open-file-dialog-bug-vba-vb-net/td-p/...
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 5 of 14
RoyWickrama_RWEI
I was trying hard to save the files in a different folder without success. Finally, I saw this information. Having got to do with iLogic, it is unfair that we can't save files in a different logical place.
I appreciate if someone helps to override the file save location as shown in the code below (can't save in the location required)
oFileDlg.InitialDirectory = "C:\$WF_DHAMAG\Libs_DHAMAG\RL001 FASTENERS\Assemblies\Reserve List\New Folder\"
oLocation = "C:\$WF_DHAMAG\Libs_DHAMAG\RL001 FASTENERS\Assemblies\Reserve List\"
oFileDlg.FileName = "RECT.idw"
oFileDlg.CancelError = False
'On Error Resume Next
oFileDlg.ShowSave()
MessageBox.Show("File not SAVED.", "Dialog Cancellation")
MessageBox.Show("File " & selectedfile & " was selected.", "Dialog Selection Made")
Message 6 of 14
JarFu
The problem gone from Inventor 2018, I checked with Inventor 2016~2019 and the issue could not reproduced with Inventor 2018.3 (build 284). Could you please double confirm if you're still annoy by this problem? Many thanks!
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Message 7 of 14
bshbsh
I am having this problem on 2018.3.6 and using VBA, can not set either initialfolder nor filename on a open file dialog.
Message 8 of 14
pball
2020.1 here and below are my finding on this. Seems partially fixed in my opinion, unless this is how someone intended it to work in which case I'd disagree with that.
open file dialog
initial directory works
file name does not work
save file dialog
initial directory does not work
file name works
Message 9 of 14
hwu
My Inventor is 2020 and I need my save as dialog directory to be the file location first, then maybe go different place. However, it leads me to the previous saving location, otherwise, it will be perfect for me.
Message 10 of 14
CadUser46
Just stumbled across this in 2019.4.  FileOpen > FileName does not work.
Inventor 2010 Certified Professional
Currently using 2023 Pro
Message 11 of 14
thomas.fitzgerald
Using Inventor 2021 and InitialDirectory does not work with ShowSave()
Thomas Fitzgerald
Principal Implementation Consultant
Message 12 of 14
thaleFUWKH
Observer
Observer
I am using Inventor 2022. You can set the initial directory but it is ignored when using ".ShowSave()"
The work around is to set the the .FileName with the full path.
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.Path 'This sets the parameter but it is ignored in ".ShowSave()"
'set the file name string to use in the input box (set full path to get Initial Directory to work)
oFileDlg.FileName = ThisDoc.Path + "\" + ThisDoc.FileName(False) 'This works
'oFileDlg.FileName = ThisDoc.FileName(False) 'This does not work
'work with an error created by the user backing out of the save
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'oFileDlg.ShowOpen()
Hope this helps others
Message 13 of 14
d.turksemaFYBBN
Thanks! This work around did the job for me.
Message 14 of 14
charles4L34S
InitialDirectory still isn't in Inventor 2024, however your workaround is working perfectly, thanks.
