[iLogic] How to set sheet names to drawing and model iproperties?
Tom_VS
Message 1 of 8
Tom_VS
To save time I want to set my sheet names to display as: "drawing iproperty (company)"-"model iproperty (part number)".
Example: The drawing iproperty under company is set as "CoolCompany". The model part number of the first drawing in the first sheet is set as "L0201". After running an iLogic rule, the first sheet name would read out as: CoolCompany-L0201
While looking through this forum, I found part of the solution as follows:
SyntaxEditor Code Snippet
Sub Main
    If TypeOf ThisDoc.Document Is DrawingDocument Then
        Dim dwgDoc As DrawingDocument = ThisDoc.Document
        For Each dwgSheet As Sheet In dwgDoc.Sheets
            If dwgSheet.DrawingViews.Count > 0 Then
                modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
                modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
                prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value
                If Not String.IsNullOrEmpty(prtNumber) Then
                    dwgSheet.Name = prtNumber
        Next
End Sub
This however, only grabs the iproperty from the model. It lacks the drawing iproperty I would like to include. I tried mixing and matching various solutions on this forum, but my programming knowledge is abysmal. I couldn't find a solution. Can anyone help fill in the missing code?
Thanks in advance,
Tom
P.S.: great forum and great contributors. It helped me a ton so far.
Replies (7)
Message 2 of 8
bradeneuropeArthur
Sub Main()
    comp = a.ActiveDocument.PropertySets.Item(2).Item("company")
                    dwgSheet.Name = comp & "-" & prtNumber
        Next
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 8
Tom_VS
Thanks for the reply.
I tried your code but I get an error:
Error on Line 4 : a has not been declared. The item may not be accessible due to the associated security level.
Message 4 of 8
bradeneuropeArthur
Mistake:
dim a as application
a = thisapplication
put this in it/…..
OR:
Sub Main()
    comp = ThisDoc.Document .PropertySets.Item(2).Item("company")
        Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 8
Tom_VS
Thanks for the correction.
However, another error popped up: Operator & is not defined for Property type and string -.
Message 6 of 8
bradeneuropeArthur
Sub Main()
                    dwgSheet.Name = comp.value & "-" & prtNumber
        Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 8
Tom_VS
Awesome, worked like a charm!
Message 8 of 8
bradeneuropeArthur
Your thanks are appreciated.
between the jobs there were some mismatches.
Sorry for that...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
