iLogic Help - Code for taking ipt iProperties to IDW iproperties
simon4D86F
Message 1 of 13
simon4D86F
Hello Everyone,
I have been trying for some time and failed.
I would like a piece of code that I can use in my drawings template that will copy the iProperties from within the IPT or IAM that is placed on the drawing and place the copied iproperties within the iproperties of the IDW.
The main reason for doing this, or at least trying is so that when I place IDW's into the vault, the iproperties fields are not left blank.
Creating forms within ipt's and iam's is no problem, I can and have done that, but when it comes to VB Code, lets be honest, I am crap and just cannot get my head around the language.
Can anyone help?
Many thanks
Replies (12)
Message 2 of 13
Sergio.D.Suárez
Hi, Here is an example in ilogic, I put the fragment to select the view because sometimes you have views of different parts and you may want to transfer only the properties of a part to the drawing file.
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oView As DrawingView
oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select View")
If oView Is Nothing Then Exit Sub
oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'Get the properties of the reference model of the view
oPartNumProp = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
oReviNumProp = oModelDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
oDescripProp = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
oStocNumProp = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value
'Transfer the properties to the drawing file
oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = oPartNumProp
oDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value = oReviNumProp
oDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value = oDescripProp
oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value = oStocNumProp
 Here you have more descriptions of how to access the properties, you have to write the names well, if you do not do it, you will return an error.
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
I hope I was clear. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 13
simon4D86F
Hi @Sergio.D.Suárez ,
Many thanks for the code, I tried it and it works fine, that is until I try to make a few changes so that the info within the part that I need, comes over to the IDW.
I have......
oDescripProp = oModelDoc.PropertySets.Item("Design Tracking Properties").Item("Project").Value
oStocNumProp = oModelDoc.PropertySets.Item("Inventor Document Summary Information").Item("Company").Value
oStocNumProp = oModelDoc.PropertySets.Item("Inventor Document Summary Information").Item("Keywords").Value
oDoc.PropertySets.Item("Design Tracking Properties").Item("Project").Value = oProjProp
oDoc.PropertySets.Item("Inventor Document Summary Information").Item("Company").Value = oCompanyProp
oDoc.PropertySets.Item("Inventor Document Summary Information").Item("Keywords").Value = oKeywordsProp
and the Error message I get is....
"Error in rule: iProperties to Drawing, in document: XXX-XXX-XXXX-001.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
Can you tell me what I am doing wrong please
Many thanks
Message 4 of 13
I was able to figure out that the line giving problems is:
But I don't know enough about code yet to tell you why.
Message 5 of 13
Sergio.D.Suárez
try this line of code
oStocNumProp = oModelDoc.PropertySets.Item("Inventor Summary Information").Item("Keywords").Value
Best Regards!
Mechanical Designer
Message 6 of 13
Sergio.D.Suárez
oStocNumProp = oModelDoc.PropertySets.Item("Inventor Summary Information").Item("Keywords").Value .Value
oDoc.PropertySets.Item("Inventor Summary Information").Item("Keywords").Value = oKeywordsProp
 Best Regards!
Mechanical Designer
Message 7 of 13
simon4D86F
Thanks for the reply and help.
I have tried the code and it is working in a manner.  It copies the Revision over and the Project name, however, the project name ends up in the Description column.
I also removed a .Value from this line after I still get the error message, Did I do right by removing it?
I did try the code with and without the extra .Value, and still get the same error message....
"Error in rule: iProperties To Drawing, in document: XXX-XXX-XXX-XXX-004.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
I know you mentioned that you hadn't figured out the error, but I will gladly admit, this is above my capabilities.....
Message 8 of 13
Sergio.D.Suárez
JajaSmiley Frustrated. I'm sorry. Delete the duplicate string ".value" . Must be unique string. Regards
Mechanical Designer
Message 9 of 13
simon4D86F
Hi Sergio,
I have removed the extra .value.
I still get the same results, Projects goes to Description and nothing else happens plus I still get the error message.
I have tried rewriting it in the manner that you have suggested and have also tried rewriting it using the info from the site you recommended, however, I just end up getting error messages or the code throws a fit and will not even run.
Message 10 of 13
Jesper_S
Hi.
I have used this in the past. Don't know if it will work.
If (ThisDrawing.ModelDocument Is Nothing) Then Return
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'read the values from the Custom iProperties in the part file
'and apply them to the Custom iProperties with the same name in the drawing
iProperties.Value("Custom", "Header 1") = iProperties.Value(modelName, "Custom", "Header 1")
iProperties.Value("Custom", "Header 2") = iProperties.Value(modelName, "Custom", "Header 2")
iProperties.Value("Custom", "Header 3") = iProperties.Value(modelName, "Custom", "Header 3")
iProperties.Value("Custom", "Remarks") = iProperties.Value(modelName, "Custom", "Remarks")
iProperties.Value("Project", "Part Number")=iProperties.Value(modelName, "Project", "Part Number")
iProperties.Value("Summary", "Company")=iProperties.Value(modelName, "Summary", "Company")
iProperties.Value("Project", "Project")=iProperties.Value(modelName, "Project", "Project")
iProperties.Value("Summary", "Title")=iProperties.Value(modelName, "Summary", "Title")
'iProperties.Value(modelName, "Project", "Revision Number") = iProperties.Value("Project", "Revision Number")
iProperties.Value("Custom", "Header 3") = iProperties.Value("Summary", "Title")
'iProperties.Value("Custom", "Mass") = iProperties.Value(modelName, "Custom", "Mass")
And then I have used this to push iProperties from the drawing back to the 3D model.
Then I don't have to go back to the 3D to update the properties.
//Jesper
Message 11 of 13
simon4D86F
Hi Jesper_s,
Many thanks, I will give this a try and get back to you
Message 12 of 13
simon4D86F
Hi Jesper_s,
Many many thanks, the code surprised me a little, I could actually follow it, understand it and of course make the required changes to it.
Fantastic result. Smiley Very HappySmiley Very HappySmiley Very Happy
My changes where as follows...
iProperties.Value("Summary", "Company") = iProperties.Value(modelName, "Summary", "Company")
iProperties.Value("Summary", "Keywords") = iProperties.Value(modelName, "Summary", "Keywords")
iProperties.Value("Summary", "Title")=iProperties.Value(modelName, "Summary","Title")
iProperties.Value("Project", "Description") = iProperties.Value(modelName, "Project", "Description")
iProperties.Value("Summary", "Category")=iProperties.Value(modelName, "Summary", "Category")
Message 13 of 13
Jesper_S
Glad to help.
But I see that I sent the wrong iLogic for the second to send iProperties from the drawing to the 3D.
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'Get the name Of the first model in the drawing
iProperties.Value(modelName, "Custom", "Header 1") = iProperties.Value("Custom", "Header 1")
iProperties.Value(modelName, "Custom", "Header 2") = iProperties.Value("Custom", "Header 2")
iProperties.Value(modelName, "Custom", "Header 3") = iProperties.Value("Custom", "Header 3")
'iProperties.Value(modelName, "Custom", "Remarks") = iProperties.Value("Custom", "Remarks")
iProperties.Value(modelName, "Project", "Part Number")=iProperties.Value("Project", "Part Number")
iProperties.Value(modelName, "Summary", "Company")=iProperties.Value("Summary", "Company")
iProperties.Value(modelName, "Project", "Project")=iProperties.Value("Project", "Project")
iProperties.Value(modelName, "Summary", "Title")=iProperties.Value("Summary", "Title")
iLogicVb.UpdateWhenDone = True
//Jesper
