iLogic GoExcel.Save
iLogic GoExcel.Save
iLogic GoExcel.Save
Hi All,
Could you tell me the way for "saving as" an excel file and creating a new copy from Ilogid rule, please?.
I see that exists the order "GoExcel.Save", but not "GoExcel.SaveAS".
Thanks in advance.
MechMachineMan
Hi. Use a combination of this call with the resources found by googling "excel + vba + msdn" and you should be able to get there.
oExcelApp = GoExcel.Application
oExcelWB = oExcelApp.Workbooks.Open("c:\file name.xlsx")
'or oExcelWB = oExcelApp.ActiveWorkbook
'Below only needed if you want to do worksheet things. 'oExcelWS = oExcelWB.Worksheets("Sheet Name")
oExcelWB.Save...
https://msdn.microsoft.com/en-us/vba/excel-vba/articles/workbook-saveas-method-excel
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
