Ilogic gives error if part is not inside assembly when i try to update parameters
Charlies_3D_T
Charlies_3D_T
I am writing an ilogic that changes a lot of parameter in part level inside an assembly. Now it's an assembly where some sub assemblies are suppressed. So here my problem starts. If i want to send a parameter to a part that exists but is suppressed inside the assembly i get an error. Is there a simple solution that it just ignores this and go to the next line of code?
Thank you!
JhoelForshav
Hi @Charlies_3D_T
If you want to ignore errors and just proceed to the next line of code, have you tried just adding the line:
On Error Resume Next
At the top of your code? 🙂
Charlies_3D_T
@JhoelForshav
Haha that fixed it never tought about that command! Thanks!
But also a question is there an option that it collects all the errors and shows them at the end of the ilogic what parts that were missing?
JhoelForshav
Hi @Charlies_3D_T
If you have the component-names in a changing variable you could do something like this example:
Sub Main
Dim oReturnString As String = "Errors:"
Dim oName As String
On Error GoTo ErrorLine
oName = "Comp1"
MsgBox(ThisApplication) 'Something that causes an error
oName = "Comp2"
MsgBox(ThisApplication) ''Something that causes an error
MsgBox(oReturnString)
Exit Sub
ErrorLine :
oReturnString = oReturnString & vbCrLf & oName
Resume Next
End Sub
