ilogic to delete the sketchsymbol in the sheet
chenQS35U
chenQS35U
Hello everybody. i had a problem.
i want to delete the  sketchsymbol in the sheet. But it can't run.
I was the first time to try the ilogic in this month.
thanks for you to help me.
Dim oSketchedSymbolDef As SketchedSymbolDefinition = oDrawDoc.SketchedSymbolDefinitions.Item(SURFACE_TEXTURE)
' judge suface texuture existence
For Each Sheet In SketchedSymbolDefinition
	If oSketchedSymbolDef.Name  = SURFACE_TEXTURE Then
	oSketchedSymbolDef.Delete
Next
JhoelForshav
Hi @chenQS35U
Do you want to delete all sketchedsymbols with the name "SURFACE_TEXTURE" from the sheet?
Dim oSheet As Sheet = ActiveSheet.Sheet
For Each oSymbol As SketchedSymbol In oSheet.SketchedSymbols
	If oSymbol.Name = "SURFACE_TEXTURE" Then oSymbol.Delete
Next
chenQS35U
Thanks you for your help. That's wonderful!
I tried to modify the code.  And resolved my problem.
