Ilogic - get idw iproperties from assembly occurences without opening idw
01:58 PM
- Mute
- Permalink
- Report
Good afternoon,
I have some ilogic that I have been tweeking. I open an assembly, then run the rule and it looks for all the IDWs of all the component occurences in the assembly and then it opens each IDW of the occurences, grabs a custom iproperty and writes it to a cell in excel and then closes the drawing.
I am wondering if there is a way to access the iproperties of the IDW without opening it. I am currently using:
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw" oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oDWGNo = oDrawDoc.PropertySets.Item("Inventor User Defined Properties").Item("Drawing Number").Value
All my assemblies and parts have the same filename and location as their respective idw files.
Here is the whole code in its entirerty:
SyntaxEditor Code Snippet
'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If oPath = ThisDoc.Path oPath = Right(oPath, Len(oPath) - InStrRev(oPath, "Vault Working Folder")-19) oPath = "\\ODESSA-SRV2\CAD-Data\Design PDFs" & oPath & "\" 'get PDF target folder path oFolder = oPath Dim sToday As String sToday = Now 'sToday = Left(sToday, Len(sToday) - InStrRev(sToday, " ")) sToday = Left(sToday, InStrRev(sToday, " ")-1) sToday = Left(sToday, InStrRev(sToday, " ")-1) sToday = (sToday).Replace("/", "-") oExcelName = oFolder & oAsmName & " - " & sToday & ".xlsx" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - -'Shell("explorer.exe " & oFolder,vbNormalFocus)'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models'this expects that the model has a drawing of the same path and name 'If OpenOrPDF = True 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly, change to false if you want to run it invisibly excelApp.Visible = True 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = False 'check for existing file If Dir(oExcelName) <> "" Then 'workbook exists, open it excelWorkbook = excelApp.Workbooks.Open(oExcelName) ExcelSheet = ExcelWorkbook.Worksheets(1) Else 'workbook does NOT exist, so create a new one excelWorkbook = excelApp.Workbooks.Add End If 'Insert data into Excel. With excelApp .Range("A1").Select .ActiveCell.FormulaR1C1 = "DRAWING NUMBER" End With With excelApp .Range("B1").Select .ActiveCell.FormulaR1C1 = "PDF PATH" End With oRow = 2 PDFPath = "\\ODESSA-SRV2\CAD-Data\1_ENGINEERING\DRAWING FILES\" For Each oRefDoc In oRefDocs On Error Resume Next idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw" oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3) ' if PDF exists and is open or read only, resume next oDWGNo = "" oDWGNo = oDrawDoc.PropertySets.Item("Inventor User Defined Properties").Item("Drawing Number").Value If oDWGNo = "" Resume Next Else 'Insert data into Excel. With excelApp .Range("A" & oRow).Select '.ActiveCell.FormulaR1C1 = PDFPath & oDWGNo & ".pdf" .ActiveCell.FormulaR1C1 = oDWGNo End With ' 'oHyperRow = "A" & oRow With excelApp .Range("B" & oRow).Select .ActiveCell.FormulaR1C1 = PDFPath & oDWGNo & ".pdf" End With oRow = oRow + 1 'set all of the columns to autofit excelApp.Columns.AutoFit 'save the file excelWorkbook.SaveAs (oExcelName) oDrawDoc.Close End If Next '- - - - - - - - - - - - -
