Change size - Content Center
CCarreiras
Mentor Mentor
CCarreiras
Hi!
I use this vb routine to change Content Center sizes within a family of elements.
In previous versions it work very well, but now it's working very erratic.
Any sugestions to solve this, or tips for a better method to do this operation?
Conditions:
Change the size of a Standard Content Center part (no need to change to a different family, only the size)
The Content center is in a custom folder inside the project folder
The size is changed based in the change of a parameter inside main asssembly
The parts are in the first level of the main assembly, not in a sub-aasembly.
Test attached.
Also check the video to resume the issue.
Thanks a lot for your help.
I'm not a power programer, and now i'm lost... i used this method in a few iLogic assemblys, and now i can't make them work well.
CCarreiras
Vladimir.Ananyev
Th discussion was continued here
http://forums.autodesk.com/t5/inventor-customization/change-size-content-center/m-p/6008127#M61228
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
