iLogic form feature activation and suppression code tidy up
GKPByDesign
GKPByDesign
I have created code to activate different features using the logic form, it then populate a custom prop for export.
It works perfectly, but I am not a coder, would any recommend a tidy up at all?
If Cut = "None" Then
Feature.IsActive("Box Section") = True
Feature.IsActive("U Channel") = False
Feature.IsActive("Angle Section") = False
Feature.IsActive("Model A") = False
Feature.IsActive("Model A - Small Side") = False
Feature.IsActive("Model B") = False
Feature.IsActive("Model B - Small Side") = False
Feature.IsActive("Model C") = False
Feature.IsActive("Model D") = False
Feature.IsActive("Model E") = False
Feature.IsActive("Model F") = False
End If
If Cut = "Model A" Then
Feature.IsActive("Model A") = True
End If
If Cut = "Model A - Small Side" Then
Feature.IsActive("Model A - Small Side") = True
End If
If Cut = "Model B" Then
Feature.IsActive("Model B") = True
End If
If Cut = "Model B - Small Side" Then
Feature.IsActive("Model B - Small Side") = True
End If
If Cut = "Model C" Then
Feature.IsActive("Box Section") = False
Feature.IsActive("Angle Section") = True
Feature.IsActive("Model C") = True
End If
If Cut = "Model D" Then
Feature.IsActive("Model D") = True
End If
If Cut = "Model E" Then
Feature.IsActive("Model E") = True
End If
If Cut = "Model F" Then
Feature.IsActive("Model F") = True
End If
If Feature.IsActive("Model A") Then
Model_Type = "Model A"
End If
If Feature.IsActive("Model A - Small Side") Then
End If
If Feature.IsActive("Model B") Then
Model_Type = "Model B"
End If
If Feature.IsActive("Model B - Small Side") Then
End If
If Feature.IsActive("Model C") Then
Model_Type = "Model C"
End If
If Feature.IsActive("Model D") Then
Model_Type = "Model D"
End If
If Feature.IsActive("Model E") Then
Model_Type = "Model E"
End If
If Feature.IsActive("Model F") Then
Model_Type = "Model F"
End If
'change Custom iProperty Name to desired Custom iProperty Name
Dim propertyName1 As String = "MOD"
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Try
'set property value
oProp = oCustomPropertySet.Item(propertyName1)
Catch
' Assume error means not found so create it
oCustomPropertySet.Add("", propertyName1)
End Try
'set custom property value; Change Custom iProperty Name to desired Custom iProperty Name;
'change UniqueFxName to the name of your User Defined Parameter
iProperties.Value("Custom", "MOD") = Model_Type
'processes update when rule is run so save doesn't have to occur to see change
iLogicVb.UpdateWhenDone = True
chandra.shekar.g
Autodesk Support
Autodesk Support
@GKPByDesign ,
Try below iLogic code
ElseIf Cut = "Model A" Then
ElseIf Cut = "Model A - Small Side" Then
ElseIf Cut = "Model B" Then
ElseIf Cut = "Model B - Small Side" Then
ElseIf Cut = "Model C" Then
ElseIf Cut = "Model D" Then
ElseIf Cut = "Model E" Then
ElseIf Cut = "Model F" Then
End If
If Feature.IsActive("Model A") Or Feature.IsActive("Model A - Small Side") Then
ElseIf Feature.IsActive("Model B") Or Feature.IsActive("Model B - Small Side") Then
ElseIf Feature.IsActive("Model C") Then
ElseIf Feature.IsActive("Model D") Then
ElseIf Feature.IsActive("Model E") Then
ElseIf Feature.IsActive("Model F") Then
End If
Try
'set property value
Catch
End Try
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GKPByDesign
Hey Chandra,
While I can see you have condensed the code a little, I am after if any code to safe guard my work, or prevent errors, If you think the code is ok, then I will leave as is
