iLogic First Angle Projection
Message 1 of 12
Hi all,
I have an iLogic rule that creates a base view and section view in a sheet. Currently, I have the active style in the document set to a custom one with first angle projection. For extra measures, I even have a few lines of VB code in my rule that sets the active style to my custom style and sets the FirstAngleProjection property as true.
SyntaxEditor Code Snippet
Dim oStyle As DrawingStandardStyle = oDrawingDoc.StylesManager.StandardStyles.Item("Core Drafting 2015")
oStyle.FirstAngleProjection = True
oDrawingDoc.StylesManager.ActiveStandardStyle = oStyle
 However, my base view and section view STILL come out as third angle projection and I have no idea why.
Any help is appreciated.
Replies (11)
Message 2 of 12
BUMP.
Really need help with this. I'm stuck and have tried everything. What is weird is I let the iLogic code run up to the point where it creates the sketchline on the base view (the line that the section view is derived from) and commented out the "addsectionview" code. I then right clicked the sketchline and clicked "create section view" and it was first angle projection!! Just like I needed!! So obviously the issue is something to do with the addsectionview function itself. Please! If anyone knows how to get past this hurdle I will be extremely grateful!
Up to here, everything is iLogic
Then I added the section view manually
First angle projection!!! Then how come it comes out as third angle when I use the addsectionview() function in iLogic?
Message 3 of 12
Another bump!
Message 4 of 12
JimmyDoe
Do you only want the section view to be first angle? And have the rest of the views on your page be third angle?
Message 5 of 12
No, I need everything to be first angle! No where in my iLogic code, template, or style have I specified third angle so I have no idea why it keeps defaulting to third angle when creating views with the code!
Message 6 of 12
JimmyDoe
Do you have the projection type setting set to first angle?
Message 7 of 12
Yes, I have it set to first angle in all the styles.
Message 8 of 12
JimmyDoe
Can you attach your drawing template?
Message 9 of 12
MechMachineMan
If you cant get it sorted out you could try using the control definition / command:
AssemblyHalfSectionViewCmd
To get the program to place it just like you are manually.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 10 of 12
Can you give me a little bit of detail on how I would use that? I can't find any info on it.
Message 11 of 12
BrandonBG
I haven't tried this, but DrawingSectionViewCmd is the command for the section view in a drawing.
AssemblyHalfSectionViewCmd is a section view in the model environment.
This post is pretty useful:
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Commands work in iLogic, too.
Brandon
Message 12 of 12
Figured it out!!
It is the "Reverse Direction" function under the SectionDrawingView class. For some reason it defaults as the opposite direction of first angle projection.
