iLogic extract plate dimensions
joris.engelbertink
joris.engelbertink
Hi all,
I would like to extract my plate dimensions with some iLogic code.
I already have this working when plates are drawn aligned with the x-y-z axis. Does someone has an idea how to get proper results when parts have a rotation with the x-y-z axis? This issue pops up when working with Multi Body Parts.
My current solution is to first create a sheet metal part, flatten it and extract x-y-z dimensions, but its quit time consuming.
Any ideas?
Thanks in advance.
Grt, Joris
marcin_otręba
bradeneuropeArthur
If you use Sheetmetal these properties are available:
Sheetmetallength
Sheetmetalwidth
Use these as customproperties
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
