02:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have a code that I will share on my network with other users. I have saved it in a shared network as an external rule. However I do not want the rule to be triggered by events, I want to be able to run it with a simple click when the drawing is open. If I understand it correct, this will be like using iTrigger, however iTrigger only work if the code is saved in the document?
In Excel this is easy, just save code as add-in on shared disc and then add it to quick access toolbar to trigger it.
Any idea?
Thanks.
