ILOGIC - EXCEL
ILOGIC - EXCEL
ILOGIC - EXCEL
Hi all
I have a spreadsheet that I have ilogic writing data too and is working well. However, I'd like to adapt the code a little.
Previously, I had ilogic check a column in an excel spreadsheet for the document number of my open inventor drawing. If it found a matching cell it then wrote data to various cells in the excel row.
I'd like now that ilogic searches - as before - for the document number and If it finds the document number AND cell C is empty then it writes some data.
can anyone shine some light on this please? )
SyntaxEditor Code Snippet
'Search for the file name in column A
For oRow = RowStart To RowEnd
If (GoExcel.CellValue("A" & oRow)) = oDocNumber & (GoExcel.CellValue("C" & oRow) = "") Then
    GoExcel.CellValue("G" & oRow) = "TEST WORKED"
MechMachineMan
Have you tried using the code you wrote with the appropriate "End if" and "Next" statements?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
