iLogic error
iLogic error
Message 1 of 42
iLogic error
Happy Tuesday all,
   Hope everyone is having a great day. I'm having a challenge with a really large iLogic program I've been working on. I will try to attach all relevant information at the end of this post. So I get the following error when I try to drive my model with the form:
"Error in rule: New Order Information, in document: AD-Trailer HL.iam
Feature.IsActive: The component named "11.5 HL Gate Rear Post CS:1" was not found." (quotes supplied)
    I also want to mention that iLogic doesn't return me to the line that is causing the error.
This particular bit of iLogic code is over 5k lines long and I know that is pretty big, but It has been working up to the point I placed the "High Lift" side options. This model  has 5 pairs of side models (sub assemblies) among many others relevant sub assemblies (all driven).
  I guess I will paste the iLogic code into a text file and attach it to this post. I will also try to post a screencast as well. Any and all help appreciated.
Replies (41)
Message 41 of 42
Milan_Nosil
Hi Mike,
I have a related issue with iLogic. Can I ask you for help?
I have the iLogic rule that makes .dxf files from a flat pattern . I made an edit in it that adds a revision number to name of a .dxf files in folder.
My problem is: if a file from the content center (or components from the frame generator) is in the assembly, an error occurs.
"Error in rule: Ilogic rule, in document: sollau.iam
iProperties: The component named "DIN 933 - nahrazený DIN EN 24017 M18 :1" was not found."
Maybe I've discovered a bug, but I do not know how to fix a complicated iLogic rule (which I did not create).
Can you help me please?
Thank you.
Message 42 of 42
Milan_Nosil
I've already solved it 🙂
