iLogic Error The object reference was not set to an object instance
mk92
mk92
I took the code from this help page:
Autodesk Help Page
And made this out of it (just an extraction):
Dim newInst2 As Autodesk.Factory.PublicAPI.Objects.v2.AssetInstance = New Autodesk.Factory.PublicAPI.Objects.v2.AssetInstance() With {
            .AssetID = "41c84844-7b28-4903-bebd-365ca3a6a53c",
		.Position = New System.Windows.Media.Media3D.Matrix3D() With {
            .OffsetX = -200,
            .OffsetY = 0,
            .OffsetZ = 0
newInst2.Parameters("Length") = "400"
The code runs great until I want to change the Length. Then is says;
The object reference was not set to an object instance.
I thought "Dim newInst2 As ...." is doing exactly this. What is missing here?
Thank you.
bradeneuropeArthur
Does the parameter "Length" exist?
Otherwise create it first!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mk92
Yes the parameter Length definitely exists.
If I do it like this:
Dim Layout As Document = ThisApplication.ActiveDocument
Dim insts = api.AddAssetInstances(Layout, New Autodesk.Factory.PublicAPI.Currency.v2.IAssetInstance() {newInst1, newInst2, newInst3 })
Dim Test = api.GetAssetInstances(Layout)
For Each item In Test
	item.Parameters("Length") = "400"
Next
api.UpdateAssetInstances(Layout, Test)
It works fine, but for each asset with the parameter Length.
But I only want to edit specific assets. And for the best workflow right after they are placed in my layout.
