iLogic Error on check in
I have an Assembly with a short iLogic rule which is add and delete some components.
After 2022 update I have this error (whit inventor 2021 was working perfect) when I want to check it in Vault.
The rule it works ok...(add the component/delete component), save,but when check in...ERROR
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.set_Transformation(Matrix )
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents.ConditionallyApplyTransformation(ComponentOccurrence occurrence, Matrix matrix)
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents._Add(String occName, String file, String modelStateName, String familyName, String designation, Object[] findRow, ComponentAspects compAspects)
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents.Add(String occName, String file, PointOrMatrix position, Nullable`1 grounded, Nullable`1 visible, StringOrAsset appearance)
at ThisRule.Main() in rule: Rule4, in document 00299234.iam:line 36
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
on the line 36 it is this line....
If Single_Tower = "Include" Then Dim Tower1 = Components.Add("00321077:1", "00321077.iam", position := Nothing, grounded := False, visible := True, appearance := Nothing) Constraints.AddFlush("Flush:24", "00321077:1", "XZ Plane", "", "XY Plane", -23 mm) Constraints.AddFlush("Flush:25", "00321077:1", "YZ Plane", "", "XZ Plane") Constraints.AddFlush("Flush:26", "00321077:1", "XY Plane", "", "YZ Plane", (Tray_Width/2) + 73.05) Dim Tower2 = Components.Add("00321077:2", "00321077.iam", position := Nothing, grounded := False, visible := True, appearance := Nothing) Constraints.AddFlush("Flush:27", "00321077:2", "XZ Plane", "", "XY Plane", -23 mm) Constraints.AddMate("Mate:50", "00321077:2", "YZ Plane", "", "XZ Plane") Constraints.AddMate("Mate:51", "00321077:2", "XY Plane", "", "YZ Plane", (Tray_Width/2) + 73.05)
