iLogic Error on check in
Cosmin_V
Cosmin_V
I have an Assembly with a short iLogic rule which is add and delete some components.
After 2022 update I have this error (whit inventor 2021 was working perfect) when I want to check it in Vault.
The rule it works ok...(add the component/delete component), save,but when check in...ERROR
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.set_Transformation(Matrix )
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents.ConditionallyApplyTransformation(ComponentOccurrence occurrence, Matrix matrix)
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents._Add(String occName, String file, String modelStateName, String familyName, String designation, Object[] findRow, ComponentAspects compAspects)
at Autodesk.iLogic.Core.ForRuleCode.ManagedComponents.Add(String occName, String file, PointOrMatrix position, Nullable`1 grounded, Nullable`1 visible, StringOrAsset appearance)
at ThisRule.Main() in rule: Rule4, in document 00299234.iam:line 36
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
on the line 36 it is this line....
If Single_Tower = "Include" Then
		Dim Tower1 = Components.Add("00321077:1", "00321077.iam", position := Nothing, grounded := False, visible := True, appearance := Nothing)
	Constraints.AddFlush("Flush:24", "00321077:1", "XZ Plane", "", "XY Plane", -23 mm)
    Constraints.AddFlush("Flush:25", "00321077:1", "YZ Plane", "", "XZ Plane")
    Constraints.AddFlush("Flush:26", "00321077:1", "XY Plane", "", "YZ Plane", (Tray_Width/2) + 73.05)
       	Dim Tower2 = Components.Add("00321077:2", "00321077.iam", position := Nothing, grounded := False, visible := True, appearance := Nothing)
		Constraints.AddFlush("Flush:27", "00321077:2", "XZ Plane", "", "XY Plane", -23 mm)
		Constraints.AddMate("Mate:50", "00321077:2", "YZ Plane", "", "XZ Plane")
		Constraints.AddMate("Mate:51", "00321077:2", "XY Plane", "", "YZ Plane", (Tray_Width/2) + 73.05)
Ralf_Krieg
Hello
The error message suggests there's something wrong with the optional positioning matrix on component add. Could you try to use command without setting optional values to nothing?
Dim Tower1 = Components.Add("00321077:1", "00321077.iam",, grounded := False, visible := True)
R. Krieg
RKW Solutions
www.rkw-solutions.com
Cosmin_V
thanks @Ralf_Krieg
Nothing....it is same
