Inventor 2023 Ribbon Panel
JoAntt
JoAntt
Inventor 2023
Ribbon panel "id_GetStarted" dosnt exist anymore.
Is the changes that are made posted somwhere?
/johan
WCrihfield
Hi @JoAntt.  Here are a few links for you.
What's New in Inventor 2023
Inventor 2023 Release Notes
Overview
Wesley Crihfield
(Not an Autodesk Employee)
JelteDeJong
The following rule will write all ribbon panel names to your log. this should work on all inventor versions. You can use it to see the differences yourself.
For Each ribbon As Ribbon In ThisApplication.UserInterfaceManager.Ribbons
    Logger.Info(Ribbon.InternalName)
    For Each ribbonTab As RibbonTab In Ribbon.RibbonTabs
        Logger.Info(String.Format("     {0} ({1})",
                                  RibbonTab.DisplayName, RibbonTab.InternalName))
        For Each ribbonPanel As RibbonPanel In RibbonTab.RibbonPanels
                                      RibbonPanel.DisplayName, RibbonPanel.InternalName))
            ' -- Uncomment the following lines if you also want to see the commands --
            'For Each commandControl As CommandControl In RibbonPanel.CommandControls
            '    Logger.Info(String.Format("               {0} ({1})",
            '                              CommandControl.DisplayName, CommandControl.InternalName))
            'Next
        Next
    Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
