Ilogic Emboss / Engrave
yohansampaio
yohansampaio
Good afternoon,
I need to create an iLogic rule to generate an emboss feature with an internal depth of 0.1 mm on the part.
In this case, I already have a rule that creates the sketch, and this sketch is named "Text Marking Sketch".
So, I need a rule that finds the sketch named "Text Marking Sketch" and uses it to create the emboss with a depth of 0.1 mm on the part where the rule is executed.
The sketch I create is a text object, as shown in the attached image.
One important detail is that the marking will always be done on the flat pattern view of a sheet metal part.
Curtis_Waguespack
Hi @yohansampaio, welcome to the community.
You can use this example. It will create an extrude feature with cut text on the flat pattern.
Hope that helps,
Curtis
' Get the active part document (sheet metal part)
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
' Get the sheet metal component definition
Dim oSheetMetalDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
Dim FeatureName As String = "My Engraved Feature"
Try:oSheetMetalDef.FlatPattern.Features.ExtrudeFeatures.Item(FeatureName).Delete: Catch: End Try
' Ensure we're working with the flat pattern
' Switch to flat pattern view if not already there
If Not oSheetMetalDef.HasFlatPattern Then oSheetMetalDef.FlatPattern.Edit
' Find the existing sketch named "Text Marking Sketch"
Dim oSketch As PlanarSketch =  oSheetMetalDef.FlatPattern.Sketches.Item("Text Marking Sketch")
' Create profiles from the sketch (text objects)
Dim oPaths As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
oPaths.Add(oSketch.TextBoxes.Item(1))
oProfile = oSketch.Profiles.AddForSolid(False, oPaths)
Dim oDepth As String = 0.01
' Extrude the text.
Dim oExtrudeDef As ExtrudeDefinition = oSheetMetalDef.FlatPattern.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kCutOperation)
oExtrudeDef.SetDistanceExtent(oDepth, kNegativeExtentDirection)
Dim oExtrude As ExtrudeFeature = oSheetMetalDef.FlatPattern.Features.ExtrudeFeatures.Add(oExtrudeDef)
oExtrude.Name = FeatureName
Curtis_Waguespack
@MjDeck, If you have some time can you take a look at the attached example, and let me know what would be needed to get the AddEngraveFromFace method for EmbossFeatures to work? I could not find a working example, and I'm not understanding why this example will not work.
Thanks in advance!
Curtis
Dim oDepth As String = 0.1
' Create the emboss feature using the flat pattern
Dim oEmbossFeature As EmbossFeature
oEmbossFeature = oSheetMetalDef.FlatPattern.Features.EmbossFeatures.AddEngraveFromFace( oProfile, oDepth, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
MjDeck
Hi Curtis - the symmetric option is not supported in the UI or in the API. That's mentioned in the documentation.
It will work if you use PartFeatureExtentDirectionEnum.kNegativeExtentDirection or kPositiveExtentDirection.
I had some problems with kNegativeExtentDirection, but it worked when I reduced the depth. This worked:
Dim oDepth As String = "0.05 in"
Mike Deck
Software Developer
Autodesk, Inc.
