Ilogic edit cotrol type missing
Geertvdheide92
Geertvdheide92
I am trying to create a little bit of Ilogic.
But when i am creating a form, the possibility of edit cotrol type, i can only choose text box.
i tried creating a multi value parameter, but this didnt help anything.
The parameter should just be an option between 2 text options.
kind regards.
Geert van der Heide
bradeneuropeArthur
This is only possible with a multi value parameter.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Geertvdheide92
I already tried creating a multi value parameter, entered the different values but the option was still impossible 😞
bradeneuropeArthur
Check this link!
forums.autodesk.com/t5/inventor-customization/ilogic-form-help-drop-down-box/m-p/7660201
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Mike.Wohletz
If you have created the for prior to changing the parameter to multi-value then you will need to remove the item from the form and then add it back. It seems like it should change to follow the type but I have found that it does not.
Mike W.
