iLogic: Display Line Numbers
c_stulz
Message 1 of 9
c_stulz
Hello, is it possible to display line numbers in iLogic window?
May be it is very easy but I am to blind to see it Smiley Sad
Greatings Christoph
Replies (8)
Message 2 of 9
mcgyvr
Nope.. Line numbers in the ilogic editor dialog box are not possible.
Message 3 of 9
c_stulz
Hello mcgyver,
thank you for the quick answer.
Then I will go and take it for a whish on the ideastation.
Message 4 of 9
David-Truyens
Hi @c_stulz,
can't find the ideastation post on line numbers? Do you have a link or should I create it myself?
David
Message 5 of 9
It is possible to see on which line you are in the lower right of the Ilogic Editor as shown in below screenshot.
However it is not possible yet to show the numbers in front of the line (Which is quite a shame....). Needless to say, I voted for your idea.
Message 6 of 9
j.pavlicek
Please provide link to the idea you mentioned. I'd like to vote for it!
Inventor 2022, Windows 10 Pro
Sorry for bad English.
Message 8 of 9
fredw1444
Hi, Christoph
I'm not sure if you've discovered this already, but the Autodesk Inventor 2022.2 Update added line numbers to the iLogic rule editor. My thanks to Randall Mabery of IMAGINiT Technologies for pointing this out.
Message 9 of 9
Curtis_Waguespack
Inventor 2022.2 and beyond will show the line number in error messages:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-log-get-code-line/m-p/1080987...
We can also use the logger to get the line number:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/to-retrieve-line-number-in-the-code/...
